oil pressure bouncing around . . . >
Old 07-13-2004 | 10:20 AM
BlownBajaOnHavasu
Default oil pressure bouncing around . . .
while at around 3500 to 4000 r.p.m. my oil pressure gauge is bouncing around
erratically between 30 and 50 lbs (502 engine normally runs about 40-45 lbs oil pressure)
oil pressure is fine at idle
oil level is fine
i'm thinking it could be the sender
any thoughts?
where is the sender located on a 1997 502?
Old 07-13-2004 | 10:40 AM
Krumbsnatcher's Avatar
Default Re: oil pressure bouncing around . . .
Hmmm,
Are you seeing this on both motors or just on your port motor? I think you should change your screen name to mpiMagic34onHavasu
LOL
Krumbsnatcher is offline
Old 07-13-2004 | 12:17 PM
BlownBajaOnHavasu
damn krumb, 535 posts . . . post whore
just the port motor.
i would change my screen name if i knew how.
are you gong to havasu this weekend? it's supposed to be hot, and a chance
of thunder storms.
Old 07-13-2004 | 12:24 PM
Jealous? I believe that motor has to work harder to turn your dual Hydraulic steering such that is constantly under load, therefore creating heat differences. Could be a sensor though, just my thought.
I am not sure Lake Havasu Water just called and said we dumped 9000 gallons of water in our backyard. Low lifes turned my water on, I bet at the construction site behind my house and forgot to turn it off.
So i am up in the air, besides i still have that fuel problem with the pickup tubes. I can sure use your help moving tonight the big stuff TV, Refridgerator etc.
let me know. I like thunderstorms they are all around havasu they barely ever hit us.
We can run my boat it is here too.
GoCiggie31
7
08-19-2007 06:07 PM
dockrocker
17
08-05-2005 09:30 PM
mleslie951
27
11-08-2004 08:03 PM
FlyFast
13
05-10-2004 11:39 PM
