496 Mag
Old 07-14-2004 | 07:29 AM
bikinilover's Avatar
Question 496 Mag
My motor runs at 180 degrees. Is this to hot for this motor? It has been this way since day one.
bikinilover is offline
Old 07-14-2004 | 11:38 AM
Default Re: 496 Mag
After a hard run mine will run up to about 180, but then it cools down to about 170..
bcolmsted is offline
Old 07-14-2004 | 02:13 PM
Default Re: 496 Mag
My port runs about 180 and the starboard about 175
Bajaforce is offline
Old 07-14-2004 | 04:42 PM
blue thunder's Avatar
Default Re: 496 Mag
As long as your oil temps are staying below 250F after WOT runs, 180F coolant temp is fine.
BT
blue thunder is offline
Old 07-14-2004 | 05:42 PM
Hydrocruiser's Avatar
Arrow Re: 496 Mag
BT
At 250F most conventional oils are cooking.
Hydrocruiser is offline
Old 07-14-2004 | 10:40 PM
Wink Re: 496 Mag
Bikinilover
The Merc. 496's come with a closed cooling system and a 160 degree thermostat. Most engines will run about 10 degrees warmer than the stat under light load conditions and may go to 20 degrees after a hard run. The temp of the water you are running in will also raise your operating temp depending on where you are boating.You might want to check your temp guage for calibration, 5 to 10 degrees off on some is common. Also make sure your coolant cap is holding pressure as a pressure leak here will raise the cooling system temperature some also. Doesn't sound like you have any serious problem as the Merc computer would go into the guardian mode if you were to hot.
Raylar
Raylar is offline
Old 07-15-2004 | 07:13 AM
Default Re: 496 Mag
Thanks for the input! Sounds like I am OK. I will change the impeller at the end of the season for piece of mind.
mg503
Baja
14
04-03-2013 04:50 PM
TeamPSI
23
12-10-2007 05:23 PM
apexer
11
07-20-2007 07:24 PM
westcoaster
3
08-08-2005 11:24 AM
NVRENOUGH
3
02-18-2002 12:25 PM
