BBC T-stat bypass hose, do I need it??? >
Old 07-14-2004 | 08:34 PM
Default BBC T-stat bypass hose, do I need it???
Here's the set up;
502 running a circulating pump and factory T-stat housing with CMI headers using the lower individual tubes for exhaust water and the fittings on the elbows plugged.
Do I need to use the bypass hose connected from the the water pump to the intake?
Shah Mat is online now
Old 07-14-2004 | 09:03 PM
mopower's Avatar
Toxic FORMULA
Default Re: BBC T-stat bypass hose, do I need it???
It allows the water to circulate while the t-stat is closed. This causes the heat off of the heads and block to reach the t-stat before the heads and block to get to hot. I have the same setup WITH the bypass hose. Without it I would think it would take the t-stat a lot longer to realize it's warm.
mopower is offline
CigDaze
8
08-09-2007 06:17 PM
rv
0
06-26-2006 12:40 PM
SmallPP
0
02-23-2005 05:56 PM
kennyo
3
04-29-2004 07:28 PM
Waterfoul
7
07-03-2002 09:58 AM
