Lower shift cable replacement >
Old 07-19-2004 | 11:34 AM
Default Lower shift cable replacement
Hi and HELP !!!!
Can the lower shift cable on a Bravo drive be replaced on the PORT engine with both engines installed ? this is in a Fountain ?
I'v e done it on a starboard engine but things look much tighter on the Port engine.
ed
Interceptor is offline
Old 07-19-2004 | 01:51 PM
Wally's Avatar
Were doomed!
Default Re: Lower shift cable replacement
there should be no reason to pull the engine out to replace the shift cable. You will need to remove the outdrive to unscrew the cable nut though
-Wally
Wally is offline
Old 07-19-2004 | 03:40 PM
Thanks Wally. I knew about pulling the drive from replacing the cable on the other ( starboard) engine. Looking at this ( port) engine access seemed tougher and figured I'd ask here.
ed
Bryan Rose
3
07-24-2008 08:53 AM
DrFeelgood
Drives and Lower Units
5
11-05-2007 09:42 AM
bsirk
Fountain
0
07-18-2007 02:34 PM
awsomethunder
9
04-30-2007 08:52 AM
bikinilover
2
03-25-2005 05:47 PM
