Leaking drive oil in bilge?? >
Old 07-19-2004 | 09:26 PM
BAJA WILL's Avatar
Registered User
Default Leaking drive oil in bilge??
Yea I am scared that I may be leaking some drive oil into the bilge?? What can be causing this?? Their is no rainbows in the water but after about 5 hours of use I have to keep filling up the drive oil resivoir. I have never had this problem before, I have around 260 hours on this drive 2001 model XZ. A friend told me some seals may have worn out but i have never heard of that ??
All input appreciated
WILL
BAJA WILL is offline
Old 07-19-2004 | 09:34 PM
Default Re: Leaking drive oil in bilge??
Do you have the old school drive bottles, aka round ones, check there first, just my .02
JPD Motorsports is offline
Old 07-21-2004 | 07:33 AM
WildThing's Avatar
My Pantera did this too.
The grease fitting on the coupler rubbed a hole in my line.
Follow the line from the drive bottle to the drive to
make sure the line isn't cut anywhere.
Also check where the line connects to
the drive to make sure the connection is tight.
WildThing is offline
Old 07-21-2004 | 10:57 AM
racer-x6's Avatar
Check The Hose And Fitting Inside The Boat If You Dont Find A Leak Pull The Drive And Check The Yoke Shaft Seal. If It Is Leaking The Boot Will Be Full Of Oil.
Good Luck
racer-x6 is offline
kemiller
11
08-22-2006 07:01 PM
Chuck
5
07-19-2005 10:03 PM
5PMSMWHR
8
07-14-2005 01:29 PM
Velocity Tom
07-16-2003 10:13 AM
Sydwayz
3
06-24-2002 08:23 AM
