Lost all 12v on the port side. GM 350/ OMC260. Ideas? >
Old 07-24-2004 | 10:51 PM
fund razor's Avatar
Default Lost all 12v on the port side. GM 350/ OMC260. Ideas?
Twice last week I ran the boat and after the run, when I shut the port down, I had no 12v at the helm when I went to restart the boat. Both times, I was able to tighten up the ground at the battery on that side, and I got 12v back.
There WAS a bad connector on that ground wire. I replaced it. But now for a third time I have nothing. And it isn't that ground. Ground is tight on the block, too.
I didn't have my VOM with me, but I connected the SB battery over on the port side just to make sure it wasn't a dead battery.
My main ignition fuse is good. The connector on the 12v pos leads on starter are tight. The main mass connector on the block is clean and tight.
I wonder if it could be shorting in the starter.
I'm going to go try again tomorrow. Any suggestions?
Thanks.
fund razor is offline
Old 07-26-2004 | 07:59 AM
fund razor's Avatar
Default Re: Lost all 12v on the port side. GM 350/ OMC260. Ideas?
for the 9 of you who looked, it was a crappy main fuse holder.
thanks to the 9 of you who looked.
TJ Bart
Fountain
5
07-24-2007 08:35 PM
merlyn1965
10
10-01-2006 10:20 PM
epeek
Fountain
18
10-17-2005 11:22 AM
Iggy
04-09-2003 01:43 PM
