Loose Rub Rail >
Loose Rub Rail
Loose Rub Rail
Old 07-27-2004 | 12:39 PM
airshares's Avatar
Default Loose Rub Rail
I noticed I can move my rub rail slightly in some areas on my boat. Is there a way to tighten it? I think it at least needs recaulking. I have a 1997 23 Scarab.
airshares is offline
Old 07-27-2004 | 01:46 PM
Wally's Avatar
Were doomed!
Default Re: Loose Rub Rail
more then likly its just screwed on and the screws are loosing their "bite" an easy and cheap fix would be to go get yourself some fiberglass resin and mix up a small batch and stick some fiberglass coated tooth picks in the holes. When it setup up solid you can trim off the excess and re-screw it back together....should be nice and tight.
Best way would be to drill through to the inside of the boat and replace the screw with a machine screw and a nylock nut on the back side.....that way it wont come appart on ya again inthe future.
-Wally
Wally is offline
nova26
07-13-2008 11:18 PM
GO4BROKE
Sonic
5
12-05-2007 09:43 PM
DOORSHOT
Eliminator
1
10-16-2006 03:53 PM
FIVEPTOHH
04-10-2006 10:08 PM
