Merc #1 and Alpha Drives >
Old 07-30-2004 | 09:52 PM
Default Merc #1 and Alpha Drives
What is the strength difference between the two? Are the gimble housing and bell housing the same? In other words, can you put a Alpha unit where a #1 was without changing the bell and gimble housings if the Alpha was stronger?
Shah Mat is offline
Old 07-31-2004 | 08:10 AM
Offshore Addiction
Default Re: Merc #1 and Alpha Drives
yes the #1 can be replaced with a alpha 1,there all strong though if built correctly and operated correctly!the gimbal housing should be checked for up and down and in and out play wear though to insure proper stability for the drive shaft alighnment!
BY U BOY
09-27-2007 05:00 AM
218diver
2
02-05-2004 06:11 PM
puder
12-10-2002 07:37 PM
Dean Ferry
11-27-2002 08:09 AM
