Ripped out a battery cable... >
Old 08-02-2004 | 10:56 AM
Default Ripped out a battery cable...
Well i was out in the boat today by yesterday, and the landing from a good sized wave broke the battery out of the nifty plastic battery tray from the factory. Unfortunately, I didn't notice in time to keep the weight of the battery from pulling the large gauge negative cable out from where it came.
I jury-rigged a ground to the engine block to get home. It looks like the negative cable was just ripped out.
It is a Baja 232 with a 496 Mag motor. Where does the negative wire attach and ground in the engine compartment??? I saw the positive (red) cables attaching, but for the life of me, I could not see where the ground wire came from.
It appears that the cable simply pulled out from the connector. If i can just find the other end, it should be a simple solder job to fix it as best I can tell.
Is this an easy do-it-yourself job or does it need a trip to the dealer to correct my mistake?
fisherchris is offline
Old 08-02-2004 | 11:27 AM
Default Re: Ripped out a battery cable...
In every boat I've ever worked on, the negative cable attached to one of the bell housing bolts (usually a stud). Check back there.
Liberator21 is offline
Old 08-02-2004 | 11:49 AM
fund razor's Avatar
Yep.
You will probably find your connector on a bell housing bolt.
Once you find it, you should be able to replace it yourself. I would use a new connector. If you use a crimp on, make sure you crimp it with a 360 degree crimper.
And maybe back that up with a flow of solder down into the back of the connector.
Don't try to use pliers.
fund razor is offline
Old 08-02-2004 | 12:30 PM
mr_velocity's Avatar
Not sure if they changed but my old baja had the neg wire attached to the motor mount at the block.
mr_velocity is offline
Dave1972
6
08-02-2005 09:05 PM
Phazar454Mag
4
06-07-2005 10:00 AM
tj309
18
05-07-2005 07:22 AM
Monty
10
06-09-2004 06:09 PM
Poorsche
3
05-11-2004 08:58 AM
