Blower on a 454 makes a 525? >
Old 08-04-2004 | 12:18 AM
Wateronthebrain's Avatar
Unhappy Blower on a 454 makes a 525?
Someone said on another site that adding a 10-71 Littlefield blower to a beefed up 454 makes it a 525sc. Is the mercruiser 525sc not based on a 502 block?
Please give me your input.
Wateronthebrain is offline
Old 08-04-2004 | 06:04 AM
Pwrbt33's Avatar
Default Re: Blower on a 454 makes a 525?
NOPE !! A Mercruiser 525Sc is built on a 454 block. They use a Crane cam and springs and used a blower built by Weind I believe, and use a Dominator on top. A nice package built today would be a 4 bolt 454 with aftermarket heads, hydralic roller and a 256 Blower Shop blower. With this set up I have seen 575 hp thats reliable.
Pwrbt33
Offshore Performance
1-877-GOFAST1
410-827-0200
Pwrbt33 is offline
Old 08-04-2004 | 08:04 AM
HiPerf2000's Avatar
a 10-71 will more than likely produce more than 525. I had a 454 w/174 B&M with cam and head work that made 560+ reliable HP.
HiPerf2000 is offline
Old 08-04-2004 | 08:31 AM
Fountain38SC's Avatar
I think a 10-71 is too big for a 454. I've got 10-71's on my 545's and had 250's on 509's. I'd call TBS and ask.
Fountain38SC is offline
Old 08-04-2004 | 08:38 AM
cuda's Avatar
I believe the 525 is a 454/420 with a blower on it.
cuda is offline
Old 08-04-2004 | 08:41 AM
Firewalker
Merc 525 SC is a 454 with a weiand 177 blower, 7.5:1 compression, 4.5 lbs of boost 1050 Holley dominator carb. 91 oct.
Good motor, needed a bigger blower!. The 256 Weiand would be my pick.
RT
Old 08-04-2004 | 11:28 AM
Firewalker, I am thinking of making 2 blower motors. If I have the 454/470 engines.If I were to rebuild them, and had Littlefeild 10-71 blowers, what specs would you go with to make the best combination for power.ie(lbs of boost,comp. ratio,cams,heads,lifters,pistons,crank)?
Old 08-04-2004 | 11:31 AM
Firewalker
Yike,
I am an outboard guy, ask me questions there. I have a little knowledge with blower motors, but would not fell comfortable recomending anything, though I would think 10 71 would be big. 6 -71 would be better I think.
RT
Old 08-04-2004 | 11:32 AM
Firewalker
jeeze I should check my spelling.......... oh well
Old 08-04-2004 | 02:47 PM
puder's Avatar
speel chekk this fokker!
no need to checl spelling.
the 525sc was a 454 with 177 blowe ron it. I have 454 bored 30 over witha 174 holley and 1050 dominator and its run very well so far and has been very reliable.
Pardon me, while I whip this out!
puder is offline
