Low fuel pressure >
Low fuel pressure
Low fuel pressure
Old 08-04-2004 | 08:44 PM
Low fuel pressure
I have a 1996 sunsation with a 502 mag m.p.i.The fuel pressure on the fuel rail is only 32 at idle but drops to 28 26 at 1500-1800.Have checked mechanical fuel pump 4-7 .Changed vst out same rail pressure.Checked fuel lines and gas tank pick up ok.Just oreded a adjustable regulator,What would cause this problem.Mercruiser wants 37 psi. ??????
riverboater is offline
Old 08-04-2004 | 09:30 PM
Dave1972's Avatar
Default Re: Low fuel pressure
Have you taken the VST tank apart? There is a small filter/screen at the pickup for the high pressure pump. I had this problem and ended up not being able to even get on plane as the screen was clogged almost 100% and allowed just enough fuel at idle. Be careful when taking the VST tank apart and you can reuse the gaskets. The filter/screen is also before each of the injectors. I took both apart and was extremely surprised at how dirty they were. Keep us posted!!!!
Dave1972 is offline
Old 08-05-2004 | 08:13 PM
Yes I pulled apart vst ,filter was clean,also check filter at regulator clean.I have heard to check ecu ,they said the voltage should change when the rpm,s go up?
BigFish
8
11-21-2007 12:49 AM
delsol
0
08-03-2007 07:27 AM
BraceYourself
4
07-03-2007 01:51 PM
Hot Boat
4
02-02-2006 08:18 PM
BillR
4
07-26-2005 07:47 PM
