Run with deck Hatches open ? >
Old 08-08-2004 | 07:33 PM
offthefront's Avatar
Default Run with deck Hatches open ?
Anyone ever run with Deck hatches open ? maybe not alot and def. not at high speed ...seems if they were turned the other way ....But I guess Anchored the need to be towrds the bow ...
offthefront is offline
Old 08-08-2004 | 07:42 PM
Formula Outlaw's Avatar
Default Re: Run with deck Hatches open ?
Mike, I never run with my deck hatches open. Wouldn't even consider it. I'd end up ripping them off in the wind, and just in case you ever stuffed it, well I don't even want to go there. I just don't think it's a good idea.
My 85' 242 had 2 portholes in the side of each hull, one fixed and one that opened with a screen. I wouldn't even run with those open.
You get your Quad IV's yet???? Russ
Formula Outlaw is offline
Old 08-08-2004 | 08:02 PM
Thanks .. I figured as much ..it just can get so hot down there ....Stuffed it ? Gulp ...
should get the props this week .....mb
Old 08-08-2004 | 08:13 PM
cuda's Avatar
I know a guy that stuffed a 38 Formula in Pass a Grille pass.
cuda is offline
Old 08-08-2004 | 09:21 PM
I back up what Outlaw said,,,,,,,,,,,,,'nuff said!!!!!!!!!!!!!
ThirdBird is offline
Old 08-08-2004 | 10:18 PM
mcollinstn's Avatar
Yes, I run with them open often.
The standard friction locks don't do a very good job though of holding them in one spot. They WILL slam open when you don't expect it, but it won;t hurt the beefy Bomar hatches.
I made a custom set of "struts" for the hatches to replace the Bomar pieces with the "friction lock wheel". My pieces have four positions with snap buttons like you see on crutches for adjustment. Press in the two buttons and move to the next position.
I run with them open only about an inch high - just enough to keep the lock latch arms from bumping the frame. Very effective Ram Air. Really does a good job of moving the heat out (with the cabin door open).
I notice 0.3mph loss on GPS WOT with all four open to the first notch. In rowdy conditions, I keep them closed.
mcollinstn is offline
Old 08-09-2004 | 07:17 AM
Now that sounds like a reasonable idea. Good thinking........
BDiggity
Cigarette
3
09-16-2008 06:54 AM
hurleyr
Cigarette
13
01-17-2008 04:29 PM
guilderoy
03-08-2007 03:30 PM
Pure Energy
02-19-2005 05:40 PM
jcboats
Baja
3
01-02-2003 11:13 PM
