311sr1 Head Compartment 2
I have noticed that the inner wall of my head compartment has started to shift around and has pulled the factory bracing out of the upper part of the headliner / underside of the deck. What is up there that the factory screwed into? Has anyone tried to fix this? If so, what did you do? I don't want to simply run a bunch of screws in there and wind up tearing them right back out. I also don't want to run lag bolts down through the deck from the outside . . .
