Trailer GVWR Question?
Old 08-15-2004 | 11:02 AM
magnuman's Avatar
Question Trailer GVWR Question?
I am looking at a trailer that doesn't have a sticker on it with the GVWR.
Is there any other markings or way that I can tell what the GVWR is on it?
It's a single axle.
Does tire size affect GVWR?
Thanks.
magnuman is offline
Old 08-15-2004 | 02:47 PM
East Coast B's Avatar
Default Re: Trailer GVWR Question?
If the tires are original, you can get an approximate value. The tires(trailer tires) have a weight rating on them. Normally, the rating of the two tires added together will be a little higher than the gross weight capacity which includes weight of the trailer itself and loaded boat. If you know the manufacturer name, they will be able to give you a definitive answer. If they are not the original tires, I would not trust any number you derive from them. Good Luck and remember to open up the bearings to assure they are ok if it's a used trailer.
East Coast B is offline
Old 08-15-2004 | 06:33 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I would not trust the tires one bit. Check out the weight capacity of the axles.
Sydwayz is offline
Fast Forward
Powerquest
11
03-07-2008 08:41 PM
chriscraft240
18
09-16-2004 01:18 PM
magnuman
0
08-15-2004 11:03 AM
Tantrum
03-14-2003 11:33 AM
BryanTuvell
6
01-13-2002 05:28 PM
