Reverse rotation engine question ... >
Old 08-16-2004 | 08:45 AM
Default Reverse rotation engine question ...
IS there anything different about the pistons and rods in a reverse rotation engine ? Or can you take a standard engine and change the cam , timing, etc .and run it . Are the pistons and rods mounted different ?
A friend did this with a motor and lost the bottom end . We are not sure of the condition of the motor prior trying it . It may have just been no good anyway . But ALL of the bottom end bearings are destroyed exactly the same ......
boot is offline
Old 08-16-2004 | 10:09 AM
Ron P's Avatar
Enjoy the show
Default Re: Reverse rotation engine question ...
I would think that the tabs that hold the bearings in place would come from the other direction in a reverse engine.
My friend has one in his fishing boat but he bought it replace the reverse engine that fried.
Ron P is offline
Old 08-16-2004 | 10:51 AM
outer42's Avatar
man i thought you were gonna get your boat running!!!!!
outer42 is offline
Old 08-16-2004 | 11:30 AM
pachangalpina's Avatar
I don't think the rods or pistons are different but the timing cover seal is different and the rear main seal is different on some.
pachangalpina is offline
Old 08-16-2004 | 11:43 AM
I assume we're talking Chevy's here.
The notches on the side of the pistons
face the rear of the block, instead of the front.
(this changes the pin/thrust offset)
hope this helps.
jt
JaayTeee is offline
Old 08-16-2004 | 11:47 AM
Steve 1's Avatar
They did a lot of them when I was at Cruise master the Arneson drives in those days required a reverse rotation engine actually I like that setup better than using a gear set to reverse rotation. I guess you could drive a mechanic crazy by slipping a reverse starter on a standard engine.All kidding aside I also heard the Oil should lead the thrust 60 degrees on the crank so a special drilled crank would be needed But the Builder would know best on this point.
Steve 1 is offline
Old 08-16-2004 | 11:48 AM
hope this helps.
jt
This is right,allso the front and rear seals are different,time gear instead of chain.
Dixie Doug is offline
Old 08-16-2004 | 12:01 PM
BigSilverCat's Avatar
four weeks ago we reversed the rotation of one of my engines to get rid of the drop boxes. we had a cam ground with the same specks but in reverse rotation and had the cam gear that drives the oil pump and distributor ground with the opposite angle. then you put a distributor gear on that is ground the opposite angle and the oil pump spins the right way, then you change the fireing order and put the starter on the other side of flywheel and away you go, total cost was $340 lunati custom cam, $27 reverse direction distributor gear, and $70 for next day shipping because i hate to wait.
BigSilverCat is offline
Old 08-16-2004 | 12:04 PM
Thanks for all the info !
I need to know this for a fact ....
I have two, off board sources, that are arguing . One says yes ,one says no .
Please let me know the facts if possible . Thank you very much ! Joe
Steve1 . I like that starter idea !
I have a 1000 that runs reverse in my cat with the arnesons . But it has been on the floor for 3 years now . (as "Outer42" knows )I can't remember how it is done ......
Thanks !
boot is offline
Old 08-16-2004 | 12:09 PM
Hey Bigyellowcat, You didn't change anything in the bottom end ? What about the seals ?
How much time do you have on them now ? Thanks for your reply !
boot is offline
