525sc valve job >
525sc valve job
525sc valve job
Old 08-16-2004 | 04:27 PM
hugeld
Default 525sc valve job
how much schould a valve job be for a pair of 525scs and is any mercruiser certified mechanic qualified
Old 08-16-2004 | 05:35 PM
Default Re: 525sc valve job
I doubt the Merc shop would do the heads themselves. Find the best head shop in town and ask your mechanic to send them there.
BadDog is offline
Old 08-16-2004 | 06:02 PM
cstraub69@comcast
The expense of $175 to $250 for the valve job, thats facing the valves and grinding/cutting the seats, is not the kicker, the kicker is the R&R of the cylinder heads by the boat shop. While apart I would check spring tension and valve guide wear.
Chris
Old 08-18-2004 | 08:14 AM
hugeld
Im located in upstate NY Albany area
Old 08-18-2004 | 08:36 AM
Hugeld-- you don't say how many hours are on those heads/last valve job. You might just want to change the valve springs. It's a lot easier now to shim/set-up the spring heights after the valve job. As Chris said, check the guides for wear before you spend money on the valve job. Probably not a concern, but check the rockers for wear too while it's all apart on the bench.
Lmarth is offline
DMAX
01-14-2008 09:41 PM
jackhammer
3
07-15-2007 10:38 PM
dykstra
4
08-13-2005 08:29 AM
bimini run
12
04-12-2004 03:24 PM
excaleagle42
4
02-20-2002 12:51 PM
