37 cabin
Old 08-20-2004 | 06:33 AM
Default 37 cabin
anyone know the measurments of the cabin height in the 37 at the highest point inside the door, and at the begining of the v birth from floor to head liner.
thanks.
rssteiny is offline
Old 08-20-2004 | 06:46 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Re: 37 cabin
What year do you want? They changed in 2003. Do you want side by side bolster measurements with the door on the Port side, or split front bolsters with the door in the center?
Sydwayz is offline
Old 08-20-2004 | 02:03 PM
pre 2003 both ways on the doors.
thanks rick
rssteiny is offline
Old 08-20-2004 | 06:05 PM
my 32 a/t has 5'2" at the center at the door end w/ a side cabin door, the door is 45" high and at the v birth 4' floor to head liner.
wondering what the 37 is.
thanks
rssteiny is offline
Old 08-22-2004 | 07:09 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Send a PM to Excursion, here on OSO. He can get the opposing side bolster setup for you. I am not sure they made a side entry/adjacent bolster boat pre-2003.
Sydwayz is offline
Old 08-23-2004 | 05:34 PM
anyone out there w/ a 37 pre 2003 w/ new deck that could give me the height of the cabin door also height of cabin at heighst point at cabin door end of cabin and height at start of v birth from floor to head liner w/ split bolsters or side by side bolsters. does the old deck have more or less head room than the new deck.
thanks 32 thunder rick.
rssteiny is offline
Old 08-23-2004 | 06:01 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
The old deck has slightly less headroom than the newer deck, and holds a bit of water on the top of the bow when the boat is sitting in the water.
To enter mine, a 2003 side by side bolster, with Port entry into the cabin, you do have to bend over a good bit. I have bumped coming out, but you get used to it. It is only a two piece swinging door, and not a flip up top, like Sonic and Fountain have. The newer 2004 etc, side entry, have a 1 piece power sliding door.
Sydwayz is offline
Old 08-23-2004 | 09:44 PM
Jassman's Avatar
I had 5'1" at the highest point at the bottom of the step in. In the head in the very corner there was 5'7",
Jassman is offline
wickd.1
Saber
12
12-18-2006 06:10 PM
Sydwayz
Activator
7
09-05-2006 05:25 AM
ActiveFun
Powerplay
9
06-05-2006 08:46 AM
Audiofn
10-20-2004 12:56 PM
Formulaproject
02-01-2003 03:03 AM
