Mercury Racing Remote Oil Filter >
Old 08-23-2004 | 07:50 PM
Default Mercury Racing Remote Oil Filter
How do you know which line is out and which is the return on a remote Mercury oil filter unit????
Active Mike is offline
Old 08-23-2004 | 08:22 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Mercury Racing Remote Oil Filter
Assuming you mean the oil filter t-stat unit used on the HP500's?
Ports on side with t-stat unit :
Port closest to the mounting plate= OUT to cooler
Remaining port closest to filter= IN from cooler
Ports on Bottom of unit:
Port Closest to mounting plate= IN, from block pad's offset center pad(Out from oil pump)
Remaining port closest to filter=OUT, on to the center port at the block pad.
US1 Fountain is offline
Old 08-23-2004 | 10:14 PM
US1
Thanks for the info. That is what I was looking for. I failed to mention the lines which fed the oil cooler.
Do you know what temp the stat is to open?
Velocity Vector
0
04-03-2008 01:45 PM
RLW
0
08-30-2005 08:16 AM
docmanrich37
13
08-09-2005 06:49 AM
powerguy
5
08-04-2002 07:44 PM
powerguy
Fountain
2
08-04-2002 05:17 PM
