Port Motor Won't Rev Past 2K RPM? >
Old 08-23-2004 | 08:09 PM
Default Port Motor Won't Rev Past 2K RPM?
350's & Alpha's. Starboard side is fine. Port side will start, idle and rev to redline in neutral with no problems. Will rev to 3K and hold fine in neutral (I didn't want to hold it at any higher RPM's than 3K in neutral). When in gear, under power will only rev to 2000 RPM's then starts to bog and sputter. Below 2000 RPMs it seams to be fine and pulls strong. If I put it back in neutral it is fine, just won't go in gear. I didn't try it in reverse as I've been told Alphas don't like high RPM's in reverse. Any ideas?
BajaFresh is offline
Old 08-23-2004 | 09:18 PM
micky dee
Default Re: Port Motor Won't Rev Past 2K RPM?
check water fuel seperator, it could be full of water! w had this problem and found out that the seperator was contaminated with h2o.
Old 08-23-2004 | 09:23 PM
micky dee
also check and or replace the small fuel filter in the carb. this could be plugged causing a restriction in fuel flow! starving the engine of fuel.
Old 08-23-2004 | 10:35 PM
Thanks, Micky Dee. I'll check both.
Old 08-23-2004 | 11:04 PM
CAPTAIN CHUCK's Avatar
Hey Bro I Am Going Through The Same Problem With My Bajas 454 Merc . She Revs Good In Neutral, But Under Load Nothing Past 2200 Rpms. These Are The Things I Did In This Order...changed Fuel/water Seperator Filter, New Plugs And Wires, New Ignition Coil, And Now Having The Carb Rebuilt. I'll Let You Know If That Solves The Problem. I'll Keep Checking To See What You Come Up With. Good Luck.
CAPTAIN CHUCK is offline
Old 08-24-2004 | 07:00 AM
J-Bonz's Avatar
Can you narrow it down to be either fuel, spark, or compression? This would greatly help in solving the problem.
Good luck,
Jack
J-Bonz is offline
Old 08-24-2004 | 08:55 AM
My carbs were just rebuilt and rest should be okay but certain. I will change fuel filters / H2O seperators today and see what she does. I'm still thinking is has something to do with the drive as it runs fine in neutral and in gear up to 2K rpms she pulls pretty strong. Maybe a bearing or alignment?
Old 08-24-2004 | 11:38 AM
I had a similar problem.
After changing filters, and before tearing into carbs or anything else, hook up a small external tank to the fuel pump, and see if the problem goes away. This will either point to, or eliminate the fuel tank/pickup/vent from the possible list of causes. My boat died at about 2000rpm, but idled fine. Changed pump and filters... no help. Then while I was out, and the engine died, I switched to a 6 gallon portable tank right at the filter inlet (before the pump). Problem went away, and boat flew. Turned out to be a bad anti-siphon valve on the tank.
Liberator21 is offline
Old 08-24-2004 | 11:59 AM
fund razor's Avatar
(Don't mean to hijack)
Hey Lib... my problem was the cable. Thanks for the help.
(We now resume helping Baja Fresh)
fund razor is offline
Old 08-24-2004 | 12:11 PM
robyw1's Avatar
WARNING, WARNING Will Robinson
Low Fuel Pressure, Low Fuel Pressure
robyw1 is offline
