alpha cutout microswitch >
Old 08-23-2004 | 08:47 PM
glassdave's Avatar
Neno the mind boggler
Default alpha cutout microswitch
anyone know where i can get a couple of those micro switches that cut the ignition when you shift. had one go bad over the weekend and would like to get a replacement and a spare. i checked the BAM sight and it was listed as discontinued by merc. thanks
08 OPA High Points Champion
glassdave is offline
Old 08-23-2004 | 08:50 PM
Default Re: alpha cutout microswitch
I don't really see how it could go bad. I took one apart on my last boat thinking it was bad. It was just a straight piece of metal bridging contacts on each side. I believe I was quoted 70.00 for a new one. Might pull the rivets and look in it for that price.
steve is offline
Old 08-23-2004 | 09:02 PM
Reed Jensen's Avatar
Electronic supply houses sell micro switches... I had the ones on my Kiekhaufer trans levers go bad.. I found suitable replacements with rollers on the ends for about 4 bucks each.
Reed Jensen is offline
Old 08-24-2004 | 01:32 AM
Try NAPA. they have a marine parts book with just about everything in it.
Mike
goob is offline
Old 08-24-2004 | 04:42 AM
cuda's Avatar
It's far more likely your lower shift cable is bad. They get corroded and don't snap back fast enough so that the switch doesn't kill the engine.
cuda is offline
Old 08-24-2004 | 07:45 AM
glassdave's Avatar
cuda- all my cables are new TFXextremes. i fired up the motor and manually pulled up the shift bracket back on the riser and it did not cut the engine when the switch was actuated. i did the same with the other engine and it killed it. everything else seems to be in pretty good working order.
never thought of napa. i will try there and maybe some elec. supply places.
Old 08-24-2004 | 07:59 AM
Mbam's Avatar
Offshoreonly Advertiser
There is a replacement kit, PN 864363A1, includes a new shift bracket, new style switch and the shift assist spring thngy, same as on the newer drives. This will improve the shifting quality overall. Dave, the cable that Cuda is talking about is the one that connects the shift bracket to the drive.
Mbam is offline
Old 08-24-2004 | 09:12 AM
glassdave's Avatar
Mark do you have the kits avaliable? sound like somthin i might like to get. the cables to the drives are new merc parts aswell. just replaced them all when i put the new shifters in. by the way those cable ends i got from you worked great. thanks again
Old 08-24-2004 | 09:27 AM
Mbam's Avatar
Yep, in stock, You can order them online at http://www.mercruiserparts.com/partsByNumber.asp
Mbam is offline
HPJunkie
Drives and Lower Units
6
01-27-2008 11:20 AM
superwrench0166
3
05-29-2007 06:34 PM
GregP
7
01-14-2003 09:26 AM
imq707s
2
04-05-2002 07:30 PM
