How do I get ~450hp out of Merc 454 -95? >
Old 08-24-2004 | 02:42 PM
tomas_wallin's Avatar
Question How do I get ~450hp out of Merc 454 -95?
How do I get ~450hp out of Merc 454 -95 without getting too poor doing it?!
I have been thinking of some kind of supercharger but doesn't really know where to begin... What else do I have to change with the engine to get a supercharger to work?
Thanks,
Tomas
tomas_wallin is offline
Old 08-24-2004 | 03:19 PM
Official OSO boat whore
Default Re: How do I get ~450hp out of Merc 454 -95?
Give us what you have to work with. You can do this very easily with a 174 blower or work a small amount and do it N/A.
Cord is offline
Old 08-24-2004 | 03:25 PM
Is it a 7.4, 300 or 330 hp 454, or a 365 hp motor?
Gary Anderson is offline
Old 08-24-2004 | 03:33 PM
Stormrider's Avatar
JC Performance Engines
I'd like to know this too.
I've got a 454 365mag. No blower for me though.
Stormrider is offline
Old 08-24-2004 | 03:53 PM
HiPerf2000's Avatar
Had a 174 B&M on a stock 330 that dynoed 450hp. Only thing changed were exhaust valves to inconel.
HiPerf2000 is offline
Old 08-24-2004 | 03:58 PM
articfriends's Avatar
It really depends on your budget and if your starting with a mag motor or standard big block. If your starting with a std motor you might be better to sell it and start with a 502 mag (for the price difference between your old motor's value still running-1000-1500 $ and a long block 502-5200$ (4000$,) you probably would spend that much in exhaust,headwork etc and still have a tired cast piston,cast crank motor that can't take much abuse. Let us know your hours on motor,mag or std and your budget,Smitty
articfriends is offline
Old 08-24-2004 | 06:13 PM
I did exactly what you did on my Scarab 21. I started with the 1991 454 Merc Bravo 330hp! The reason why I wanted to stay with the 454 vs. the 502 is I wanted to keep the blower under the engine hatch with no protrusions. The 174 would fit. I was aware that it had cast pistons and crank and not so great exhaust valves! I figured what do I have to lose, if I blow this one I haven't lost anything! I can still use the parts on a properly prepared engine! I installed the 174 on the bone stock motor. Updated to a blower carb that Teague custom marine tuned for a blower, added a Holley red electric fuel pump in addition to stock. Went to a full MSD ignition system! (If I did it again today I would have use the DUI ignition from performance distributors) Changed the prop, set the timing to a modest 28 degrees total advance and 5 psi of boost! RESULTS! Don’t know the horse powers gain, I did get an additional 12 mph on GPS! I was Happy! I ran it without a hitch for three years, and logged 226 hours on it without a problem! I only wanted a year or so! The final demise of the engine was a corroded Merc exhaust that led to a hydraulic lock! Which I didn't care because I had a new motor on the stand! I am sure I am leaving something out, if you have any concerns or questions please ask!
Bryan
bpine is offline
Old 08-24-2004 | 09:17 PM
bpine,it sounds like that worked out good for you,the 502 is identical to your 454 in external dimensions though so you wouldn't have had to worry about a engine hatch problem compared to your 330 hp motor.
Old 08-24-2004 | 09:51 PM
DonMan
Just glad to hear about those big block dimensions....
I was thinking of replacing the 396 in my Chevelle with a 540. I was very concerned about getting that thing in the engine compartment.
Old 08-24-2004 | 10:30 PM
Donman,i was trying to clarify something to bpine because he said "i stayed with the 454 vs. the 502" because of engine hatch clearence? After re-reading his post i see he meant the 174 blower would clear (which would be too small for bigger motor).sorry to insult your intelligence,Smitty
