understanding prop pitch?
Currently I have 15x23 3 blades on SSM 2. What would happen if I went with a set of 15x25 3 blades with everything else being the same. I found a really great deal on them and was thinking of gettng a spare pair of props.
Official OSO boat whore
If the 23's were the perfect prop, ie low slip and the rpm's in the correct range, then you would go slower because the engine would now be below the correct rpm range. If things are less than perfect, ie there is too much slip, or the engine is above the desired rpm limit, then you should go faster with the 25's. If the engine is below the desired rpm then you will go slower because the engine will be bogging. Ultimatly, if the price is right, just make the sale contingent on you being able to try them. Naturally, you should pay shipping both ways. If you damage the prop in any way, then you own them, so be careful.
Well, I've been on this board for 3 years now and I finally got one right.
Go figure.
Go figure.
Throttle Up
I'm running twin Gen V 454 mag efi's, 385hp
Actually just found a slight ding in the starboard side prop, I'm going to need a little assistance in getting it back true
Phughes69,
Sorry to jump in your thread, thought my question was similar in nature.
Phughes69,
