need a ZZ502 camshaft.Part#12366543 >
Old 08-30-2004 | 04:21 PM
Default need a ZZ502 camshaft.Part#12366543
GM says back ordered and I'm trying to get going in time for the inlaws visit from Hungary. I built my starboard(454) with this cam and would like to keep them the same.It's a 224/234 dur and .527/544 lift.I have the lifters.Thanks for your help.
cooltoys61 is offline
Old 08-30-2004 | 06:07 PM
rmbuilder's Avatar
MarineKinetics
Default Re: need a ZZ502 camshaft.Part#12366543
cooltoys61,
Those cams have been on backorder from Chevrolet for about 6 weeks. The good news is my info shows Courtesy Chevrolet in Phoenix has 6 in stock. The # is 1-602-248-7710.
Bob
rmbuilder is offline
Old 08-30-2004 | 06:38 PM
Thank you,
I just found one at another dealer and ordered it a few minutes ago but thanks for the help,I'll hang onto that # in case there is a problem.
Old 08-30-2004 | 06:40 PM
cig1988's Avatar
Hi Bob, You helped me with a cam part# a while back...thanks. Would you happen to know anyone that has 990 BBC head castings?
cig1988 is offline
Old 08-30-2004 | 07:15 PM
rmbuilder's Avatar
MarineKinetics
cig1998,
I will get back to you ASAP. How many do you need?
Regards,
Bob
Old 08-31-2004 | 07:28 AM
Airpacker's Avatar
I have a brand new take out from a zz502 that was marinized, never run.
Airpacker is offline
Old 08-31-2004 | 02:01 PM
Pat McPherson's Avatar
What is the idle quality of a 454 or 502 using the ZZ502 cam?
I have one that I am thinking of using when I rebuild this winter.
Hoping the engine would idle smoothly around 800???
Patrick
Pat McPherson is offline
Old 08-31-2004 | 03:29 PM
Yes it's pretty mild ,maybe a little more "rump" than 454 mag cam,,but I picked up 4 mph going from a 454 mag to my new gen6 just on one side,,now I fried my other old 454 mag and will put another rebuilt gen 6 on the that side. According to BAMs boat speed calc I picked up about 80 HP. I'm using the stock heads that I roughly ported(they are 230cc so almost a big oval)and I had the block decked .030" so I have about 9.25:1 compression.I think I'm around 450hp with very good torque. Only prob is I need to change modules to get less total advance. These vortecs don't like more than 30 total so I'm ideling at 7deg adv os so.It does idle well there but more advance on the low end would be better.
hpy540's Avatar
Hey air packer how much do you want for it give me a call... 15-344-6690
hpy540 is offline
hpy540's Avatar
715-344-6690
hpy540 is offline
