Mounting of power steering cooler
Charter Member #139 /Moderator/Platinum Member
I have some carbed 500 hps I am in the last throws of putting together and cant remember how the cooler mounted iit appears it might be from a oil pan bolt with a spacer so the bracket clears the lip on the pan
Is this the way it mounts or is there something I am missing
If you have the small seperate ps cooler I belive it mounts behind the distrib bolted to the flywheel cover after the sea pump. The oil cooler mounts low port side of motor. Best to check how your hoses are laid out.
Originally Posted by BadDog
Klaw,
I think it uses a bolt from the motor mount pad if you do not have the cradle mounts.
thank guys I had found my dissassemby pictures and it was on the lower motor mount bolt fit lik a glove
