Towing with an H-2 Hummer
Arial6Navy
I am thinking about buying an H-2 Hummer and want to tow my 33' Eliminator Daytona. I think the towing weight is about 9,500 pounds. A few people have told that the hummer will handle this with issue. Please give me your opinions on these ASAP. I would like to purchase now.
Bad Kittie
Bad Kittie
Towing Capacity 7,000#
http://auto.consumerguide.com/auto/n...x.cfm/id/38137
You'll be OK, but watch the mountains and your breaking distances!!!
actually the capacity is 6750, I just test drove on and that was the first thing I looked for in the manual, that is why I shyed away from it, cuz if I am gonna get 10 mpg, it atleast should tow something.
H2 hummers look tougher than they really are,i worked on the transmission on one,it's the same 4l60e that a 1/2 ton z-71 and tahoe use(also the same one a 4.3 s-10 uses w/exception of a 1-2 shift servo),not indestructible like the 4l80e in the bigger trucks use,Smitty
Here you go. Don't waste your time, this will be safe and weighs 8800lbs dry. Now that is safety. I don't know why people spend 50k on a toy when you can spend 50k on a truck. This is an 03 PSD.
