Oil Scoop!! >
Oil Scoop!!
Oil Scoop!!
Old 09-09-2004 | 03:15 PM
Full Throttle 525's Avatar
Default Oil Scoop!!
Allright guys:
I was concerned about going from Mercury Racing's 25-40 to Mobil 1 15-50 in the 525 efi. I called Mercury and they said that it probably works great but that they haven't tested it and know that their oil works fine, so that's what they stay with. He did say that if the engine failed and they found it was the oil's fault, then the warrantee wouldn't be good.
What do you guys run and think?
Full Throttle 525 is offline
Old 09-09-2004 | 03:36 PM
Cattitude's Avatar
Default Re: Oil Scoop!!
I run Mobil 1 either 15-50 or 20-50 in my 575, I'm pretty sure my manual even says to run syn. As long as you meet the SAE ratings they specify (AP, AG etc. they can't claim anything.
OK- looked it up in the service manual..
"Preferred oils
Premium grade 20W-50 automotive oil SJ, CF/CF-2 rating"
Can't find anything about use of syn except not to mix oils.
Cattitude is offline
Old 09-09-2004 | 04:49 PM
Pantera24's Avatar
Ron play it safe and run the Merc stuff....the last thing anybody wants is a warranty issue that they wont cover because of something like oil. Once the warranty expires then go with the syn. just my .02
Angel
Pantera24 is offline
Old 09-09-2004 | 05:05 PM
BRUCE SEROFF's Avatar
Most of the guys, I know that are racing, are using the M-1 15/50.
BRUCE SEROFF is offline
Old 09-09-2004 | 09:50 PM
Thanks Guys:
Maybe I should stay with the Merc recommended and then switch after the year warranty to be safe. Again, thanks for the input.
Ron
Old 09-10-2004 | 08:05 AM
Stormrider's Avatar
JC Performance Engines
I know Jo uses the M1 15-50 in the F2 boat.
at least thats what he told me...
so now thats what i use.
Stormrider is offline
Old 09-13-2004 | 08:22 AM
Cattitude's Avatar
Something else not mentioned, I think it's universally agreed that break in should be on dino oil.
Brandon
08-30-2007 06:58 PM
29scarab
Cigarette
1
01-08-2007 10:48 PM
29scarab
12-29-2006 03:02 PM
Wardey
12-18-2002 06:10 PM
32fever
01-30-2002 05:28 PM
