7' Beam Or 8' Beam = Pro's And Cons??? >
Old 09-10-2004 | 12:23 PM
FASTERDAMITT's Avatar
Default 7' Beam Or 8' Beam = Pro's And Cons???
There's a few race boats out the with 7' beam and kickin butt in F1( 29 & 30's). What about pleasure use.
FASTERDAMITT is offline
Old 09-10-2004 | 01:51 PM
JUSTONCE's Avatar
Default Re: 7' Beam Or 8' Beam = Pro's And Cons???
tab usage.
JUSTONCE is offline
Old 09-10-2004 | 02:12 PM
Stormrider's Avatar
JC Performance Engines
For pleasure I'd like 8ft.
Actually, my wife says a couple more inches would do it....
Stormrider is offline
Old 09-10-2004 | 02:32 PM
glassdave's Avatar
Neno the mind boggler
traditionaly the 7 foot beam boats are better in rough water.
Martin- is your boat more or less sensative to tab input? just curious because i have never thought about it until you mentioned tab usage as and i know your excal is a 7 footer. hows it running by the way? we have been hitting the bay on thursdays for dinner and drinks (no water ) have you guys been mostly hanging at Kellys?
08 OPA High Points Champion
glassdave is offline
Old 09-10-2004 | 02:34 PM
Originally Posted by JUST ONCE
tab usage.
What about around the dock ect..
Stormrider, try a strap-on!!!
Old 09-10-2004 | 02:40 PM
Strip Poker 388's Avatar
Rob
I would think the 7 beam would be less stable the reason for the tabs usage.
Strip Poker 388 is offline
Old 09-10-2004 | 02:48 PM
Stormrider's Avatar
Sorry, but the wife won't let me borrow it.
Old 09-10-2004 | 04:36 PM
I new someone would say they suck. I just can't imagine one foot making so much difference. But, almost all V's are 8'. Why not 9' ??
Old 09-10-2004 | 05:55 PM
krypto 1 in CT
the 27 activator has a 7 foot beem and does good in f1.if you think about it it would probably need more tab down than a 8ft to keep from rocking but would slice through waves better like a knife.is super boat 7 ft beam also?.my kryptonite is a 8 foot beam i like the hull alot but if there is 1 thing I would change about it would be to go from 22 degrees to 24 and leave the 8 foot beam.
Old 09-10-2004 | 06:42 PM
Phantom, Superboat, Activator, Magnum,older Cigarette's to name a few, I know there's others.
24 deg, 7' beam
