gauge accuracy >
gauge accuracy
gauge accuracy
Old 09-13-2004 | 09:43 PM
mattittuck 1's Avatar
Default gauge accuracy
how accurate are gaffrig redline speedometers
mattittuck 1 is offline
Old 09-13-2004 | 09:51 PM
mcollinstn's Avatar
Default Re: gauge accuracy
Not very, unless you use a carefully setup pitot assy in a clean water position (this is hard to find on a step bottom).
No real reason to spend big bucks on a pitot style speedo. GPS speedo is far more accurate, and usually not much more $$. GPS speedos don't respond as quickly on accel, but they are more accurate.
A paddlewheel tournament speedo is very accurate up to about 50 mph. Above that, they lose accuracy due to dirty water.
mcollinstn is offline
Old 09-13-2004 | 10:20 PM
how does my speedo get its reading? there isn't a visible sensor by the drives
Old 09-14-2004 | 12:03 AM
mcollinstn's Avatar
If you are using a pitot tube speedometer, it will get its pressure reading from either a separately mounted pitot assembly OR from a pitot hole in the gearcase of your lower unit (assuming you have a standard Bravo or Alpha drive made since 1990). The drive pitot hole will be appx 3" above the propshaft centerline. They work well on installations with a low x dimension and a nonstepped hull.
Old 09-19-2004 | 06:26 PM
i have a 2003 292 fastech with twin 6.2 320hp mercs. when i flush the engines i notice that the port side prop very slightly spins is this normal?
Old 09-20-2004 | 12:19 AM
Grog's Avatar
Re: gauge accuracy
I have a 1999 271 Fastech. Gaffrig speedo and GPS readings are within 1 mph of each other up to 72 mph. I understand my case is an exception.....not a rule.
Grog is offline
speed demon
5
06-26-2005 09:34 AM
Dave1972
2
03-31-2003 10:14 AM
huge
6
05-06-2002 08:23 PM
hammereab
5
03-12-2002 04:48 PM
