Help with GM cam timing events?specs,
on the #12552296 duration @ .050 intake is 204 degrees with .480 lift and exhaust is 209 degrees with .483 exhaust
On the 24502611 @.050 intake duration is 211 with .511 lift and exhaust duration is 230 with .540 lift. It has a lobe sep angle of 110 degrees. I believe this is a gen6 roller cam
They are both Gen VI roller cams.
What engine are you planning to run one in?
I have run them both in my 454 with oval port heads, not much difference between the two.
I guess the HO cam is designed more for the rectangular port heads
Patrick
Patrick
Cam # 24502611
@ 0.050
ID 211
ED 230
LSA 112
ICL 108
IVO -2.5 BTDC (- indicates ATDC)
IVC 33.5 ABDC
EVO 51 BBDC
EVC -1 ATDC (- indicates BTDC)
ECL 116
Overlap -3.5
@ 0.050
ID 211
ED 230
LSA 112
ICL 108
IVC 33.5 ABDC
EVO 51 BBDC
ECL 116
Overlap -3.5
Cam # 12552296 listed
@ 0.050
ID 204
ED 209
LSA 118
ICL 115.5
IVO -13.5 BTDC (- indicates ATDC)
IVC 37.5 ABDC
EVO 45 BBDC
EVC -16 ATDC (- indicates BTDC)
ECL 120.5
Overlap -29.5
@ 0.050
ID 204
ED 209
LSA 118
ICL 115.5
IVC 37.5 ABDC
EVO 45 BBDC
ECL 120.5
Overlap -29.5
Cam # 12552296 measured
@ 0.050
ID 206
ED 211
LSA 118
ICL 115.5
IVO -12.5 BTDC (- indicates ATDC)
IVC 38.5 ABDC
EVO 46 BBDC
EVC -15 ATDC (- indicates BTDC)
ECL 120.5
Overlap -27.5
@ 0.050
ID 206
ED 211
LSA 118
ICL 115.5
IVC 38.5 ABDC
EVO 46 BBDC
ECL 120.5
Overlap -27.5
Pat,
Cam # 12366543 measured
@ 0.050
ID 224
ED 234
LSA 110
ICL 108
IVO 4 BTDC (- indicates ATDC)
IVC 40 ABDC
EVO 49 BBDC
EVC 5 ATDC (- indicates BTDC)
ECL 112
Overlap 9
@ 0.050
ID 224
ED 234
LSA 110
ICL 108
IVC 40 ABDC
EVO 49 BBDC
ECL 112
Overlap 9
