Hydraulic steering questions >
Old 09-16-2004 | 10:01 PM
SledgeHammer's Avatar
Default Hydraulic steering questions
I added a hydraulic helm after previously putting on an add on single ram hydraulic system. Now my steering wheel never seems to end up in the same place. Anyone have any idea why? Could it be air in the system? Any advice how to purge the air? Should hydraulic steering eliminate the low speed I/O wander?
SledgeHammer is offline
Old 09-16-2004 | 10:12 PM
Default Re: Hydraulic steering questions
It won't help wandering at idle on a single engine boat.
Griff is offline
Old 09-16-2004 | 10:39 PM
Tinkerer's Avatar
Hydraulic wont center like cable stearing does.
the conection between the wheel and the drive is liquid and there is slippage ( best term I could think of ) so don't expect the wheel to stay centered.
Tinkerer is offline
Old 09-17-2004 | 04:41 PM
Roger 1's Avatar
Your wheel does`nt stay centered because it is a fluid connection instead of a mechanical one, that`s just the way it works. Get a three spoked wheel so it does`nt make you crazy.
Roger 1 is offline
Old 09-17-2004 | 06:30 PM
Thanks Guys. Apparently mine is working like it is supposed to. You are right, It does drive me crazy. I guess I will get used to it.
Old 09-19-2004 | 06:41 AM
Sledge Hammer
Call the people you bought the helm from.
They will know the precise answer.
Installing the helm and bleeding the system does take some effort, you have to add a little fluid at a time and keep checking the reservoir. After several turns from left to rignt and some bleeding back at the cylinder you eventually will get all the air out.
Post what you find out.
Brian
Big Boys Toys is offline
Old 09-19-2004 | 10:12 AM
Full hydraulic helms always have some internal leakage so you loose your center position. To see what I mean, with the pump engine running hold the system against full steering lock. The wheel will creep. Because of the design of hydraulic helms it's usually worse in one direction than the other, I can't remember which direction. I've been in singles that with just the right conditions you would need to keep turning the wheel slightly to make up for the leakage against the steering torque.
Falcon is offline
Old 09-23-2004 | 08:13 PM
Falcon, what you describe is exactly what mine does. Thanks for the feed back everyone.
Old 09-23-2004 | 08:32 PM
Do you think you still have air in the system? Does the reservoir level change much with the engine running vs not? It will change some due even with all of the air out because of line expansion under pressure.
Falcon is offline
Old 09-24-2004 | 09:06 AM
Wobble's Avatar
SORE MEMBER
I installed a WPM full hydraulic system with dual rams. It took 3 weekends of boating and adding fluid before the system completly bled all the air out. The steering pretty much stays centered unless I force the steering against full lock. Very happy with the system except it is still a little heavy at 800rpm. Does any one know of an upgrade for the power steering pump?
Mark
Wobble is offline
