Anyone with Desktop Dyno >
Old 09-21-2004 | 09:06 AM
Default Anyone with Desktop Dyno
I recently bought a 24 daytona with the following engine specs. Could someone run the build through Desktop Dyno to get me a ballpark curve on HP and torque?
Mark V 454 Merc 4-bolt main block with Std. Bore
J/E forged pistons with 9.8 to 1 comp.
ISKY Cam model RR-275/284 hyd roller
adv 275/284 @ .05 228/238
.553/.578
108 ICL
114 LSA
Square Port Std GM Heads
Hardin Marine Dart copy single plane intake manifold
Merc 500-HP 800 CFM Marine Holley
Mallory Magnetic Marine Dist set at 34 degree total advance
Stock 1996 Merc Mark V Magnum Exhaust manifolds
vegas daytona is offline
Old 09-21-2004 | 09:19 AM
Default Re: Anyone with Desktop Dyno
RPMs---HP---Torque
4000--439----576
4500--486----567
5000--505----531
5500--500----477
Might be a little optimistic because I used "small tube headers with mufflers"
RickR is offline
Old 09-21-2004 | 10:28 AM
Thanks for running the numbers. This is very good info for me as I was trying to get a base line and am looking at adding headers. I am thinking I should be around 450 to 475HP now and would like to get to 500HP. It looks like a good set of true headers might get me there.
Any suggestions from the forum on resonable $ mods to push me up over 500HP reliably. No blowers for the time being due to runnin 9.8 to 1 compression.
Old 09-21-2004 | 10:31 AM
PatriYacht's Avatar
Too Old on the board sells Lightning headers and CMI at good prices.
PatriYacht is offline
randy carlson
0
12-28-2007 09:55 AM
teamsynergy
0
06-14-2007 06:06 AM
RUSSSR1
2
06-04-2005 08:00 AM
delsol
5
05-10-2003 09:58 AM
26scarab
13
03-11-2003 09:56 PM
