serpentine belt >
serpentine belt
serpentine belt
Old 09-21-2004 | 11:36 AM
mr_velocity's Avatar
Default serpentine belt
I want to remove the power steering pump on the port motor since it's not used. Is there a shorter serpentine belt that can be found for this? Anyone know a part number. The motors are 454MPIs
mr_velocity is offline
Old 09-21-2004 | 02:35 PM
Doller Offshore
Default Re: serpentine belt
the inboard version should help since they don't use power steering.
Old 09-22-2004 | 05:00 AM
Mbam's Avatar
Offshoreonly Advertiser
Part number is 861050, you can order it here:
http://www.mercruiserparts.com/partsByNumber.asp
Mbam is offline
Old 09-22-2004 | 10:23 AM
thanks, much cheaper than replacing a pump that doesn't do anything. I'll pass along the info
Are the pumps rebuildable? The bearing is screaming but it might make a good spare to carry on board.
Advantage_Rob
07-09-2007 01:11 PM
bluewater7
0
08-18-2004 07:01 PM
26sonic
2
04-25-2003 07:12 AM
olysan
3
02-22-2003 07:25 AM
BryanTuvell
3
07-24-2002 03:34 PM
