skater style water pick ups? >
Old 09-25-2004 | 10:46 PM
i need to know if an after market company sells water pick ups that mount on the bottom of the hull instead of the back? any help!!!!!
SlickNick is offline
Old 09-26-2004 | 06:53 AM
Default Re: skater style water pick ups?
Stainless Marine has 'em. Ask Fred with Trick Marine. He's a dealer.
Due
Dueclaws is offline
Old 09-26-2004 | 09:48 AM
merlin540
teague has them also
Old 09-26-2004 | 10:20 AM
thanks guys, i am installing them on my 39 ocean express, i post pics as we go!!
Old 09-26-2004 | 06:53 PM
hey fred/too old, do you have the bottom mount water pick ups, not the ones that mount on the transom? and they are like a plate that is flush and looks like a naca duck used on nascar air intakes for the drivers? does this make sense to you, i think mti uses the same ones i am talking about?
Old 09-26-2004 | 08:57 PM
Reed Jensen's Avatar
Here is a picture of a pick-up from a MTI cat... you can see the lip extends beyond "flush"... It is NOT like a NACA duct....
Reed Jensen is offline
Old 09-26-2004 | 09:09 PM
44MTI's Avatar
Actually that lip you see is adjustable to control h2o pressure. It can be raised up to look just like a NACA Which I believe alot of race boats run them to reduce drag.
44MTI is offline
Old 09-27-2004 | 09:10 AM
hey reed, if you look close, you can see that the intake starts in front of the intake pipe, just like a naca duct, and not just a pipe sticking down!
Old 09-27-2004 | 09:54 AM
Nick-
Go to the Jaguar forum and look at the intake that I installed: Stainless Marine. This is similar to Skater's.
The pipe is extra long because hull thickness varies, but you trim the pipe. The entry into the pickup has about a 6" long "shaped-recess" ground into the hull, which leads into the pipe. The forward part of the pipe doesn't protrude: its sunk-in. The back of the pipe protrudes "maybe" 1/8": depends on the boat.
Due
Dueclaws is offline
Old 09-27-2004 | 02:31 PM
hey due, thanks for your time on this matter!!!! you know what i am talking about!!!!!
