Bravo I Trim Issues - Ideas? >
Old 10-05-2004 | 04:01 PM
Default Bravo I Trim Issues - Ideas?
Wondering what anybody's ideas might be on this. Running a 26 ft Wellcraft Nova with a Bravo I, mildly blown 454, and a 23 pitch 3-blade. When I hammer it out of the hole, it goes for a short period and then feels like I have a cavitation issue. If I baby it up until it's on plane, no problems. My trim must have slight leak as the outdrive requires fairly regular adjustments and the trim will "sag" if it sits on the trailer for a few days.
My question, is this a cavitation issue with the prop or is my trim pump not strong enough to keep the outdrive down in the water? I think it's the latter because when this "blow-out" occurs, I've noticed a little rooster tail from the prop angling upward.
Has anyone experienced something like this? Would a new trim pump fix it? Thanks in advance.
SM
Shallow Minded is offline
Old 10-06-2004 | 12:13 PM
Default Re: Bravo I Trim Issues - Ideas?
Sounds to me like you have no hole shot. I think you should play around with Props abit... very doubtful on the trim pump issue. just my .02! Good Luck MW
velo is offline
Old 10-06-2004 | 01:40 PM
mr_velocity's Avatar
Keep hammering it out of the hole and you'll be buying drives too.
mr_velocity is offline
Old 10-06-2004 | 01:50 PM
HiPerf2000's Avatar
The forward spiining motion of the prop will be forcing water backwards, thus propelling your drive further "IN" not "OUT". If anything it will force the drive inward.
How long have you have the blower setup? sounds like that prop is too small for the boat. My old boat was 25' with mild blower and i was spinning a 27 pitch 4 blade.
HiPerf2000 is offline
Old 10-06-2004 | 01:51 PM
HiPerf2000's Avatar
Either way you should be running a 4 blade if you have planning problems.
Old 10-12-2004 | 03:19 PM
Thanks for the ideas, guys. I bought the boat with this set-up, but it sure sounds like a 4-blade might be the way to go.
I've also been reading up on the removal of the "exhaust bellow" on a Silent Choice set-up. Anybody familiar with this? Thanks again. SM
Old 10-13-2004 | 12:43 AM
hillbilly24's Avatar
the exhaust bellow should be removed on thru transom and silent chioce boats. it can actually create a slight vacume in the drive and thus the prop the can cuase cavition although i don think this is the problem in your case i think you just dont have enough prop and a 4 blade like a B-1 would be a good starting point for testing. most dealers will allow you to return an undamaged and factory packaged prop in exchange for another one so you can find out waht works best without buying 20 props. I think a 24 or 26 pitch would be the place to start for you.
hillbilly24 is offline
PARADOX
0
08-13-2007 02:38 PM
chevalcabre
Fountain
1
07-06-2007 06:50 PM
Dregsz
3
10-10-2005 08:09 AM
Dave1972
9
05-27-2005 09:01 PM
Allan4
3
04-14-2003 07:09 PM
