boost & rpm
Old 10-05-2004 | 06:00 PM
CAFE's Avatar
Default boost & rpm
im currently running 4lb boost(509 intercooled, good heads, blower pistons, cmi sport tubes 8-71 blower shop blowers) my question is, when i move my boost up to 8lbs will my rpm's increase at wot. currently at 5000 if so how much ??
CAFE is offline
Old 10-05-2004 | 06:15 PM
Default Re: boost & rpm
Yes, you RPM's will rise! Its hard to say how much depending on several factors! Boat weight, FUEL, Prop,type of boat, ect! It wont be allot! On one of my Twin Turbo motors "Remember boost is boost" I have an adjustable wast-gate! I could go from 0 to 30 lbs of Boost on the fly. 0-20 I would see a 1800 rpm climb! I called it "turning up the volume"!
Bryan
bpine is offline
Old 10-05-2004 | 11:57 PM
articfriends's Avatar
you will definately gain rpm's,i would expect going from a 4lb pulley to a 8 lb pulley will give you a signifigant increase. 4lbs should give it another 100 hp even taking into account the extra friction&parasitic loss,400-800 rpm's depending how loaded down your hull is/prop etc,Smitty
articfriends is offline
Old 10-06-2004 | 12:49 AM
Cafe,
Just curious. What cabs are you running, Jets. Power valves, are they boost referenced?
Don't forget you will have to Re-jet and most likely prop change!
Bryan
bpine is offline
Old 10-06-2004 | 08:53 AM
CAFE's Avatar
i believe the carbs are 750's worked and boost referenced by c&j ???. dont have the jet sizes here with me. i think 84 72 i dont remember
CAFE is offline
GS42fun
1
01-11-2006 05:35 PM
Craney
10-02-2005 08:22 PM
baronbob
2
04-24-2004 09:30 PM
cbarnes
1
01-24-2004 07:45 PM
skunknet
7
02-25-2002 02:51 PM
