Prop Puller for #5 Wanted
Old 10-07-2004 | 05:31 PM
Lightbulb Prop Puller for #5 Wanted
I would like to Purchase a Prop Puller to assist me pulling off my prop without damaging it! Any suggestions or comments? I have searched the net and found lots of pullers for Ski and yacht's. Nothing looks like it will work on mine.
Bryan
bpine is offline
Old 10-07-2004 | 06:34 PM
Default Re: Prop Puller for #5 Wanted
Bryan-There was thread here a month or two ago. Most of the posts dealt with using a block of wood against the base of a blade or a brass rod against the hub. Ckeck it out. I just pulled the props on my #5's-no problem, but I do use anti-seize on the splines. Good Luck!
Lmarth is offline
Old 10-07-2004 | 07:24 PM
Tonto's Avatar
I'm with Lmarth on this one, I always use antiseize or grease on the prop shaft before installing the prop. Never had to use a puller.
Robert
Tonto is offline
Old 10-07-2004 | 07:57 PM
Mbam's Avatar
Offshoreonly Advertiser
Warm it up, just hot enough to feel hot - 160 deg or so, should not need a puller.
Mbam is offline
Old 10-07-2004 | 09:33 PM
Comanche3Six's Avatar
As your heating the prop hub strike the hub with a large nylon mallet. It will come loose.
Coat the splines with never seize in the future.
Good Luck
Ed
Comanche3Six is offline
Old 10-08-2004 | 04:29 PM
Thanks for the information Guys!
The Previous owner didn't take much care of the shaft!
I think he left the prop on for extended period after saltwater excursions!
I do use allot of marine grade antisize then I destroyed a new snap on mallet getting it off, Good thing is lift time warranty. I haven't tried the heating thing. I was worried about melting that plastic collar!
Now I know.
I plan to also replace the shaft here shortly!
Thanks again!
Bryan
bpine is offline
Old 10-08-2004 | 10:03 PM
Speaking of that plastic collar and the white plastic retaining ring, does anyone know where I can get replacements? Mercruiser didn't bother to respond to the message I left them. Many Thanks, Lou
Lmarth is offline
Old 10-08-2004 | 10:51 PM
Tonto's Avatar
Lmarth,
Matt at TNT, Gallen at SPEEDMASTERS, are the two that come to mind.
Robert
Tonto is offline
Old 10-09-2004 | 04:45 AM
Many thanks for the advice, Robert. I'll probably start with Gallen as I've got some other SSM questions I'd like to ask him. I've never dealt with them, but my sense is that they're top notch. I respect your opinion. May I ask what fluid you're running in your Speed Masters? Lou
Lmarth is offline
GoodTymn
Baja
9
03-01-2008 03:42 PM
Xchoke03
12
12-16-2007 08:30 PM
TBarCYa
1
06-27-2006 01:13 PM
Rage
7
11-30-2005 09:50 PM
p4-33
4
03-27-2004 12:28 AM
