Annual HP525EFI Maintenance >
Old 10-10-2004 | 06:02 PM
masher44's Avatar
Default Annual HP525EFI Maintenance
Hi All, I have an 03 525 EFI/ Bravo XR with about 70 hours on it. My plan this winter is to, (other than the obvious change of all fluids):
Impeller
check all hoses etc.
change serpentine
scan ECM
set timing
Align outdrive
pull drive and grease U Joints and Gimbal
install relief valve for lower water pressure
Does anyone recommend anything else to be done? I like to be there with the mechanic during the process to learn so any additional suggestions by anyone would be greatly appreciated or anyone who has a 525 that can give me some insight on any problems they discovered during the first 100 hours or any additional items to e replaced/fixed as preventative measures. I used the boat only 16 hours this summer and 50 last summer with no problems (other than fuel pump this year, of which I changed the regulator valve). I run it hard about 15% of the time in freshwater. I am switching to M1 20w-50 oil & M1 filter, and Redline Heavy gear lube. Thanks a Bunch, Jim
masher44 is offline
Old 10-10-2004 | 07:04 PM
restabr's Avatar
Default Re: Annual HP525EFI Maintenance
I've heard the 525's like to have the spark plugs changed every 100 hours. I've also heard that some of the ecu's are being re-programmed by merc to address transom sooting (mine are currently en-route to be re-programmed).
Like Masher I'd like to hear any other suggestions I've got 77 hours on 04 models.
restabr is offline
Old 10-10-2004 | 07:11 PM
masher44's Avatar
I did my plugs and impeller two weeks ago. No problems there. I figure there must be someone here who has more than us. Everyone I see at the lake has nothing but rave reviews about them.
masher44 is offline
Old 10-10-2004 | 07:13 PM
masher44's Avatar
Had the ECU re-programmed twice and still have soot. Very common from what I have been told... no cures yet unless I hear from someone on the board otherwise.
masher44 is offline
Old 10-11-2004 | 09:39 AM
i have a 525\ 2005 in a 288 sunsation with// its xr drive 75 hours
i fouled plugs at 30 hours had ecu reprogramed awesome ever sence.
no moore soot for me boat stays allott cleaner. i just winterized it on
sunday sad to see it go for winter . overall this engine runs great
still smell fuel but it likes it.
changes all fluids ran antifreze through it greased all fittings.
i might change plugs in spring.
rotax is offline
Old 10-11-2004 | 10:11 AM
robyw1's Avatar
Well the way to get rid of soot is lower the fuel pressure. BUT it is dangerous to do that because it will lean out on the top end. I'm sure what merc is doing is shortening the injector PW and advancing spark at idle and maybe cruising speeds when you send it in for a revised program. I wish I could see the scan of one that had this problem.
Roby
robyw1 is offline
Old 10-11-2004 | 10:20 AM
robyw1's Avatar
Impeller
change serpentine
scan ECM
set timing
Align outdrive
I recommend you leave the timing alone. No reason I can think of that it should be off.
Roby
robyw1 is offline
Old 10-11-2004 | 12:27 PM
skaterboy's Avatar
You should replace the Fuel Filter on the top of the engine if you still have the originals. I had a problem with mine where they rusted out and caused a fuel leak by the treads. The replacements we installed we sprayed with clear lacquer so they wouldn't rust.
skaterboy is offline
intouch1
Drives and Lower Units
10
04-20-2008 07:34 PM
Praetorian
12-26-2007 09:13 PM
Wardey
08-20-2003 09:43 AM
kcgbjc
06-09-2003 06:29 PM
Mark in So. MD
08-17-2002 09:14 PM
