View Poll Results: Which is all around better?
stand up bolsters
19
28.36%
sit down bolsters
20
29.85%
bench seat
28
41.79%
Voters: 67. You may not vote on this poll
backseat...
I am not sure if this has been discussed before. When under way I notice most people that ride with me stand instead of sit. What would be more effective to have for the backseat and why?
Chris, Funny you ask this question. Just yesterday a 32 Baja was next to me at the marina with 4 standup/sitdown bolsters and a bench seat. I thought this was a great setup!! I personally would rather be in a bolster than a flat back seat.
Generally speaking, I much prefer the bench in the back. It's a good all around configuration which makes loading and unloading easier, boarding easier and is more comfortable for most people, most of the time.
However, for poker runs and high-speed running, the bolster config is better. It's more secure and something to grab onto is comforting.
There should be no comparison. Sit down bolsters in the right boat allow you to brace your legs and absorb shock through your legs compared to stand-up bolsters that transfer all of the impact to your spine.
I find my bench seat makes a pretty good third bunk when that buddy has had one too many to drive home. I find that aspect of a bench seat indisposable in my smaller (24') boat.
Originally Posted by Troutly
For our type of boating (a lot of weekending and rafting off) the rear bench with two electric bolsters is the way to go. This gives a lot of cockpit room.
However, if all I did was tear up the water and run Poker Runs, then an extra set of bolsters or a rear bench turned into bolsters would be real nice.
In the edition of powerboat magazine where they covered the NYC poker run, there was a guy that made his own back seat. In the down position it was a flat bench seat. Then it was hinged towards the stern, and was able to flip up to make 3 or 4 stand up bolsters. I think it was a Nortech V ???? i think i remember a purple interior.
anyone else see this. they had a write up on the guy in the section where they covered the poker run.
I see how that would be a bit of a PITA!!
