454 magnum vs 420 engine >
Old 10-11-2004 | 12:12 PM
gripit's Avatar
Default 454 magnum vs 420 engine
What are the differences between 1988 454 magnum and 420 engine both from mercruiser? I was told the 420 is better??? Please advise?
gripit is offline
Old 10-11-2004 | 12:37 PM
Audiofn's Avatar
Charter Member #232
Default Re: 454 magnum vs 420 engine
From what I have been told they are two very different motors. The 420 will make more HP, and they have better parts in them. I believe same crank and pistons but the 420 I was told has roller rockers and so on. The Mags came I think in a few different flavors from 365hp-385hp? The 420 is obviously more.... I am sure that you will get some much more definative info....
Jon
Put your best foot forward!
Audiofn is offline
Old 10-11-2004 | 12:44 PM
Pretty much what Audio said. Roller rockers, cam, intake, carb. Not sure about CR, but I can check. Bottom end/block is about the same.
Gary Anderson is offline
Old 10-11-2004 | 12:50 PM
I believe the HP420, HP425, HP465 etc were the early "HP" motors. better parts for the High Perf engines.
TxHawk is offline
Old 10-11-2004 | 01:44 PM
PatriYacht's Avatar
Holley 800 carb, Wiend single plane intake, hotter cam, Crane gold roller rockers, high perf. exhaust system.
PatriYacht is offline
Old 10-11-2004 | 08:12 PM
gripit's Avatar
Does anybody know anything else about a 420? Are they still available? Please advise.
gripit is offline
Old 10-11-2004 | 10:00 PM
Payton's Avatar
Charter Member #927
Other than the exhaust. looks like it would take just over $1100 to convert a 365 Mag into a 420. using Summit racings catalog.
Then another $1719 for some Aluminum Edelbrock heads. How much more hp would the heads give you?
$2000 for Brodix heads
$2200 for Merlin and just a little more for Dart heads
Payton is offline
Old 10-11-2004 | 11:00 PM
blown formula's Avatar
The 420 also has the "188" casting rectangular port heads & matching Team G single plane intake manifold..... no, the 420 is no longer made, but can be duplicated... better cams are available today for it. Bare head castings now are about 700.00 each here (new) and used are not much cheaper, so aluminum heads are a good & comparitive replacement.
blown formula is offline
Old 10-12-2004 | 04:47 AM
fastlane40's Avatar
Get a crate 502.My 2 cents.
fastlane40 is offline
Old 10-12-2004 | 07:51 AM
the 420 cam is the crane #h-228/312-2s-14t1.2 or part number#132561 in the crane cataloge 228/236 duration at .050 114 lobe seperation 530/551 lift.i would upgrade to a rollerfor not much more money but a lot more torque and horsepower from th same bottom end.use a dart single plane with an 800 holley jetted up alittle
proboat-wes is offline
