Oil on transom 500 efi
All of a sudden their is oil from tail pipes all over transom and outdrive. Motor is down half a quart. Did'nt notice any performance loss, and a compression test shows all at 150+-5. Rear plugs show richer than front. Started up and everything seems normal, and no trace of oil comming from exhaust. Anyone have any idea what happeneed? Thanks John
The only thing that can make oil pump out of the exhaust is leakage through the rings or sucking oil in through the valve guides. The guides would have to be really bad for that amount of oil to suck through. I understand that your compression is good, maybe you should try a leak down test. Compression is not 100% accurate in determining the condition of the internals of a motor. Also, are you sure those rear plugs are rich with fuel and not colored from oil??
John B, 1.2 qt. dont sound like too much to be down! Are you sure it is oil? Is the 500 efi equipped with pvc valves? Disconnect the breather tubes from the valve covers and run the motor and see what, if any blow by it has.
steve
[ 09-15-2001: Message edited by: P29 SCARAB ]
steve
How about a leak in the oil cooler? 65 lbs oil pressure and less than 30 lbs of water presure= oil going into the water and out the tailpipes and all over the transom. Has this happened to anyone?
John, Does your 500 efi have the Sea water pumps with the fuel pumps (new style) on them? Its just a shot in the dark, but could the seal have gone bad ,and sucked the gear oil out of the water pump housing?
Is it on both motors, or just one?
Hope its just something simple!
Good luck,
Ron...
Good luck,
Ron...
30 psi water pressure is to high shouldnt have over 20 psi at full speed if it does you have to get rid of it before your push the head gaskets out of the engine . do you have a see strainor on the boat if you do you can put a pressure valve on this to get rid of the excess pressure through a transom fitting. you could position it on the boat and blow it on the drive
Well the oil cooler isn't the problem.Ron, this is an EFI so I don't think there is a fuel pump on the sea pump. Merlin, no sea strainers, max pressure is in the low 20's. The drives are up about 1.75 above the bottom.
The search continues
