Re-gelling the bilge, pics included >
Old 10-17-2004 | 12:02 PM
Default Re-gelling the bilge, pics included
This summer my exhaust risers corroded to the point of failure and water leaked into the heads. Exhaust was removed and heads sent out. Thankfully no internal damage!!
Went to marina 1 day to take a look, opened the engine hatch and my eyes almost popped out of my head!!! If anyone has followed my ordeals with this boat you know that there have been several diff. marinas working on these engines. Well, it now looks like a spaggetti dinner!!!! There were wires everywhere, plumbing was a mess, non-stainless and galvanizes parts all rusted, fiberglass dust from when the fuel tanks and bulkhead were replaced, corroded wire connections, and my own doing paint overspray everywhere!!!
I made the decision to pull the motors, gelcote the bilge, and re-rig all the wires and plumbing!!!
Today I finally finished sanding and prepping. I can't believe what a lousey job Sonic did! The gelcote job was horrible!!!! So I took my angle grinder and 50 grit sand paper and went to town! Now a final vacuum and rinse with acetone and I'm ready to shoot.
Attached Thumbnails Re-gelling the bilge, pics included-2003_0108_192125.jpg
Pure Energy is offline
Old 10-17-2004 | 12:14 PM
Default Re: Re-gelling the bilge, pics included
Keep us posted.
29scarab is offline
Old 10-17-2004 | 01:56 PM
glassdave's Avatar
Neno the mind boggler
what kind of gel are you using and how do you plan to mix it? will you be using waxing agent or duratech? looks like you did a nice job prepping it which is what gives the best final results.
08 OPA High Points Champion
glassdave is offline
Old 10-17-2004 | 02:02 PM
VelocityMark's Avatar
Do yourself a favor and go ahead and remove the transom Assembly's and replace the gaskets on them while you have it down that far. It makes it a lot easier to to do the work you are doing and if they ever start leaking you will wish you had done it when you had the chance. I did mine last year and at the last min decided to change mine and I am glad I did.
Attached Thumbnails Re-gelling the bilge, pics included-engingecompartment2.jpg   Re-gelling the bilge, pics included-engingcompartment.jpg
VelocityMark is offline
Old 10-17-2004 | 02:05 PM
R Addiction's Avatar
AT Cult Member #3
Wow!! I thought my bilge was clean!!!
R Addiction is offline
Old 10-17-2004 | 02:35 PM
RLW
I am with Mark in regards to removing the Transom Assemblies. I just went through the same ordeal this spring. I like the gelcoat idea.
I went with a Pettit polyurethane high gloss paint.
RLW is offline
Old 10-17-2004 | 02:37 PM
Glassdave- I got the gel from Fiber Glast and will be mixing with Duratec 1:1 as directed. I will do a final "wash down" with acetone to make sure all contaminants are out.
Velocity, I was thinking about that and probably the right thing to do!
I hope to get it done before the temp drops too much.
Old 10-17-2004 | 08:54 PM
Audiofn's Avatar
Charter Member #232
DO NOT go 1 to 1 with the Duratec if you ask me. 2-1 TOPS has been my experience. It gets WAY to little coverage if you go 1-1 and you can go 2-1 and still get the good results and advantages.
Jon
Put your best foot forward!
Audiofn is offline
Old 10-17-2004 | 09:41 PM
CBR's Avatar
CBR
www.hyperfishing.com
Looks great Pure Energy!!! I could not believe my 30SS bilge was black before I had mine redone. I assume yours was black also.
Trouble is, my engine compartment is beginning to look like spaggetti again!
CBR is offline
Old 10-17-2004 | 10:06 PM
glassdave's Avatar
you will like the duratech but like audio said watch how much you use. 2 to 1 max (thats 2 parts gel to 1 part Duratech). also what type of gun will you be using?
by the way do you have any other pics of your boat you could post? i am going to be moving up from my scorpion in the next year and i think i have my mind set on a 88 to 90 31 foot sonic ss. i have always thought they were great looking boats and good performers as well. they seem to have everything i am looking for. thanks
