Hatch actcuator wont work >
Old 10-17-2004 | 06:57 PM
epeek's Avatar
Unhappy Hatch actuator wont work
Help,I just got ready to winterize the boat & I cant open the engine
hatch! Actuator just clicks. I cant see any way to get in there to
unbolt it. I tried taking the pins out of the back,but I can only move
it up about an inch. Anybody have this happen to them?
(32 Fever) Thanks, Rick
epeek is offline
Old 10-17-2004 | 07:39 PM
jryan26's Avatar
Default Re: Hatch actcuator wont work
Ive wondered the same thing. So the batteries are charged, and it just clicks?
jryan26 is offline
Old 10-17-2004 | 07:55 PM
epeek's Avatar
Yea,full charge. It's trying to work but just wont lift it.
I even jumped the breaker because it keeps tripping it,
after toggling the switch up & down. I cant believe Fountain
didnt make a provision is case this happens.
epeek is offline
Old 10-17-2004 | 08:13 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Can you lift up at same time as operating the switch helping to take the load off the lift? Even with a full charge, my lift is slow.
I see on your other post that you have the side vents. That sounds like the most promising chance.
US1 Fountain is offline
Old 10-17-2004 | 08:35 PM
epeek's Avatar
Tried it,no luck.Just clicks or makes a ratcheting sound.
epeek is offline
Old 10-18-2004 | 07:48 AM
88Fount33's Avatar
Beak botr
Side vents with long extensions and ratchet/socket, then dedicate a set for this emergency, weld on the sockets and store in the boat for emergency purposes. I have the same "worry". They put my batteries under the hatch, and then a heavy duty dryer plug under the seat. I changed the plug to a forklift style and rigged up a set of jumper cables but would still be in the same state if the actuator failed. Sorry for your troubles, but at least you will not have to cut into your sun pad as other brands and models that do not have side hatches. I have been told horror stories such as this and still have not made up the socket/ratchet extension tools.
88Fount33 is offline
Old 10-18-2004 | 11:11 AM
bryanspeedracer's Avatar
Check you ground connections. Had the same problem and it was a bad ground.
bryanspeedracer is offline
Old 10-18-2004 | 02:06 PM
88Fount33's Avatar
Beak botr
The ratcheting sound is the sound of the clutch on the motor drive letting go. It makes this same sound when the hatch either fully opens or fully closes and you keep your finger on the switch just a moment too long. The fact that it is making this noise means that either the clutch has gone (too loose) or that there is binding due to wear, bend, or excessive friction in the ram.
Old 10-18-2004 | 05:11 PM
epeek's Avatar
Yea,same sound as when you hold the button when its open all
the way. I'm sure the units shot. Just was hopeing someone
knew a way to get at the bolt. It looks like my only shot is thru
the vents.
epeek is offline
Old 10-19-2004 | 02:06 AM
Innov500s's Avatar
I always assumed I could pull my pins in the rear and get at the bolts that way, I guess I was wrong. Good luck and keep us posted
Innov500s is offline
