Lifter ?
Old 10-18-2004 | 06:45 AM
dyno's Avatar
Charter Member #655
Default Lifter ?
will the roller lifters from a Mark 4 block work in a Gen 5????
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 10-18-2004 | 08:34 AM
Default Re: Lifter ?
Dyno
They can be used but the require machining the top of the lifter bores down to clear the tie bars it's time consuming but it can be done. Good luck Laz Mesa
MESABALANCING is offline
Old 10-18-2004 | 08:37 AM
dyno's Avatar
Charter Member #655
not worth the greif......
dyno is offline
Old 10-18-2004 | 10:49 AM
PatriYacht's Avatar
I'm using Cranes in a gen 5 right now. No machining, no problems. You guys must be thinking about gen 6's.
PatriYacht is offline
Old 10-18-2004 | 10:55 AM
PatriYacht's Avatar
I just went back to Cranes website and checked. They give the same lifter part no. for 1965- 1995. There is a note however to check for clearence under the link bar on aftermarket blocks such as Dart, Merlin.
Old 10-18-2004 | 12:44 PM
dyno's Avatar
Charter Member #655
Thanks Ian! Hows the foot?got the Black Thunder put away yet?
dyno is offline
Old 10-18-2004 | 01:42 PM
PatriYacht's Avatar
Foot's still screwed up Don. I'm going to have a peg leg for the Pirates Ball. Are you guys going?
Old 10-18-2004 | 02:18 PM
rmbuilder's Avatar
MarineKinetics
Dyno,
The Morel lifters have a longer body and deeper set pushrod cup. They will work in Mk IV, Gen V & VI blocks with standard retro pushrod length.
Bob
rmbuilder is offline
Old 10-19-2004 | 05:38 AM
dyno's Avatar
Charter Member #655
Thanks for the info Bob! Ian I think we will skip the pirates ball....
dyno is offline
Bryan Rose
1
06-14-2011 11:11 AM
Bryan Rose
Prop Talk
3
08-24-2006 09:21 AM
blue thunder
12
12-27-2004 11:32 AM
Danny_Ocean
4
05-12-2004 08:39 AM
riverboater123
2
04-22-2004 07:05 PM
