Warrining buzzer quit ?? >
Old 10-18-2004 | 10:50 PM
Strip Poker 388's Avatar
Rob
Default Warrining buzzer quit ??
2001 500efi . When ya turn the key on the buzzer usually goes off for a few seconds . It quit on the starboard motor.Any way to test it? It did sound week the last few weekends.I wonder if its just the buzzer just went out. All the gages read fine..
What ya think??
Rob
Strip Poker 388 is offline
Old 10-20-2004 | 09:21 PM
Gizmo's Avatar
Are we having fun, yet?
Default Re: Warrining buzzer quit ??
Strip, take a look at your drive oil reservoirs. One of them may be low.
Jay
Gizmo is offline
Old 10-20-2004 | 09:38 PM
offthefront's Avatar
not sure on newer rigs but older model would indicate bad oil pressure alarm sending unit ...
offthefront is offline
Old 10-20-2004 | 09:53 PM
Rob
It does not have the sensor in the drive rez.B max drives
When you turn on the key to crank the motor the alarm buzzer goes off for about 2-5 seconds then goes off . this part quick working .
Its not going off from one of the sensors telling it to. It sounds like the buzzer has gone bad . has anybody had this prob before or the buzzer go bad???
Rob
Old 10-20-2004 | 10:22 PM
rbtnt's Avatar
You can disconnect the buzzer and put 12VDC across the two leads and it will buzz if it is good.
If the buzzer is good, you are either missing the +12V that is supplied under the dash somewhere or you are missing the GND that comes from your sending unit switches.
Check your buzzer first, I had one go bad. I believe Mercury wanted $50 and Radio Shack has them for less than $5.
rbtnt is offline
Old 10-21-2004 | 01:02 AM
Rob
Thanks . I will test it and see. Is the one from radio shack the same ??
Rob
Old 10-21-2004 | 07:46 AM
Rob, I read that the buzzer works when you turn the key on and buzzes until it builds up oil pressure, is this correct. If it is, its not the buzzer. If the buzzer does not sound with the key on and the motor not running, its probably just the buzzer. I replaced a few over the years too.
shawn is offline
Old 10-21-2004 | 08:26 AM
Rob
I am pretty sure it not the oil sender. I always turn the key on then let it build fuel pressure ,by that time the buzzer had gone off,I crank it then.
It does sound like it just the buzzer gone bad .
Old 10-21-2004 | 09:26 AM
If the buzzer works while its building fuel pressure, how can the buzzer be bad?
shawn is offline
Old 10-22-2004 | 10:27 AM
Rob
Thats the way it use to work . It doesn't buzz at all know.
