Completed the compression test on my '85 merc 260 >
Old 10-24-2004 | 07:23 PM
JGB's Avatar
JGB
Default Completed the compression test on my '85 merc 260
1- 132
3- 135
5- 130
7- 133
2- 155 noticed fuel in cyllinder
4- 150 also noticed fuel in this cylinder
6- 140
8- 145
How does it stack up? what does it mean when there is a noticeable amount of fuel in the 2 cylinders? Thanks guys. at least now I assume I have arrived at decision time. Thanks for any advice.
Jim
JGB is offline
Old 10-24-2004 | 09:06 PM
mcollinstn's Avatar
Default Re: Completed the compression test on my '85 merc 260
Compression test should be run on a motor that is "warm" not cold.
Disable the kill switch (or if it does not have one, remove the coil wire from the distributor cap and ground it). Open the throttle plates.
Then check each cylinder.
When you say you saw fuel in the cylinders, please elaborate.
mcollinstn is offline
Old 10-24-2004 | 09:30 PM
JGB's Avatar
JGB
yeah it was done cold. When I removed the #2 and 4 spark plugs I noticed fuel on them.
JGB is offline
Old 10-24-2004 | 09:34 PM
offthefront's Avatar
fuel ..or water ?
offthefront is offline
Old 10-24-2004 | 09:42 PM
JGB's Avatar
JGB
definitly fuel
JGB is offline
Old 10-25-2004 | 04:18 AM
JGB you having probs or just got some extra cash ???
Old 10-25-2004 | 08:13 AM
JGB's Avatar
JGB
It's certainly not an xtra cash issue. The Problem is max rpm only 4500, This motor has a little hotter aftermarket cam. engine iis running rough, carb has been rebuilt twice in two days. I'm at my wits end.
jim
JGB is offline
Old 10-25-2004 | 08:18 AM
JGB's Avatar
JGB
Formulaz thanks, throttle was WOT during test. Carb as I mentioned in previous post has been rebuilt twice in two days ccause that's what I thought was causing the motor to run rough.
JGB is offline
Old 10-25-2004 | 08:20 AM
JGB's Avatar
JGB
And I am getting blow by from the Valve cover breathers and not just a little.
JGB is offline
Old 10-25-2004 | 08:25 AM
JGB's Avatar
JGB
was told engine had 40 hours on a rebuild. certainly can't belive that.
Jim
JGB is offline
