Who sells tires on OSO
Old 10-26-2004 | 06:43 PM
LapseofReason's Avatar
Default Who sells tires on OSO
I need 6 235-85-16 tires, My big problem is the French build the best one's.
LapseofReason is offline
Old 10-26-2004 | 07:15 PM
skaterboy's Avatar
Default Re: Who sells tires on OSO
Try the TIRE RACK, (www.tirerack.com), excellent prices and in stock,
skaterboy is offline
Old 10-26-2004 | 07:23 PM
R Addiction's Avatar
AT Cult Member #3
Mamatryed.....Mitchell is his name
R Addiction is offline
Old 10-26-2004 | 07:56 PM
buck183's Avatar
Ditto,
Buck
buck183 is offline
Old 10-26-2004 | 10:25 PM
Official OSO boat whore
Mama set me up! Just be sure you get some mounting quotes first. I got bent over on my mounting.
Cord is offline
Old 10-26-2004 | 10:27 PM
AT Cult Member #3
I'll post a number and extension tomorrow if you need it
Old 10-26-2004 | 10:34 PM
buck183's Avatar
Hmmmm......"bent over" and "mounting" in the same sentance.
Buck
buck183 is offline
Old 10-26-2004 | 10:38 PM
carter38's Avatar
Sounds like its a dually if its a 4x4 you might look into the 255/85/16's they are a 33 they look really good on the trucks and don't have rubbing issues. Just a thought you might check out.
carter38 is offline
Old 10-26-2004 | 10:51 PM
Strip Poker 388's Avatar
Rob
Buck
what about the reach around ?
Ya might look locally ,the freight may be high?
Strip Poker 388 is offline
Old 10-26-2004 | 11:11 PM
buck183's Avatar
Strip,
The reach around is considered common courtesy in most parts. Just goes without saying.
buck183 is offline
