Stud girdles??? >
Stud girdles???
Stud girdles???
Old 10-29-2004 | 08:30 AM
Strip Poker 388's Avatar
Rob
Default Stud girdles???
Will a stud girdle fit under the stock 500 efi valve covers?Are they tall enough?
Strip Poker 388 is offline
Old 10-29-2004 | 08:56 AM
cstraub69@comcast
Default Re: Stud girdles???
If they don't, you can get VC spacers from Brodix or Sterling to name a couple. Measurement is 1.125"
Chris
Old 10-29-2004 | 11:14 AM
RedDog382's Avatar
Strip,
I don't think they do. I don't know what girdles cost, but you might want to consider spending a little more to go to Jesel rockers. I think they are much more stable.
Chris
RedDog382 is offline
Old 10-29-2004 | 11:21 AM
Reed Jensen's Avatar
Damn.... I see Strip post "stud girdles"... and I expected to see hung men in women's lingerie.............
Reed Jensen is offline
Old 10-29-2004 | 11:32 AM
Me too.....
Shah Mat is offline
Old 10-29-2004 | 03:11 PM
offthefront's Avatar
I was told that stud Girdles are seldom used in marine aps ..well at lest under 750 hp ...that true ?
offthefront is offline
Old 10-29-2004 | 03:33 PM
Hey Red Dog I just had the two motors in my new (to me) Outerlimits freshened up at Gellner Engineering and we upgraded to the Jessel Shaft
Rocker Arm System. They say it way easier to Adjust plus much more accurat.
How is the Windshield doing on the Formula?
bripar77 is offline
Old 10-29-2004 | 05:08 PM
Stud girdles suck!!! Jesel or T & D shaft rockers are the way to go. Stud girdles also won't fit under stock valve covers. By the time you buy the girdles, spacer and rockers you could of nearly paid for the Jesels. Not to mention with stud girdles it may be impossible to remove the valve covers to set lash without removing the exhaust, depending on what exhaust is being run.
Just my .02!!
Craig
WETTE VETTE is offline
Old 10-29-2004 | 05:14 PM
Ms PatriYacht's Avatar
Man I am glad a guy posted that question, I never look at the tech page but I could not help it when I saw that post as the lead in on Tech section, OK I will leave now and go back to the general section where I feel at home
Ms PatriYacht is offline
Old 10-30-2004 | 09:38 AM
mcollinstn's Avatar
Stick with the U-bolt style girdles instead of the "better" sandwich style girdles. The U bolt ones take up less room.
You WILL need spacers, but only about 1/4" ish. You can get the covers off without dropping the exhaust with 1/4" spacers, but if you use the standard 1" spacers, you almost gotta pull the mans to get them off.
mcollinstn is offline
