Hydromotive P5X results are in
25 daytona single step. 7lbs procharged 502 mag
30 lab bravo =plained out good . Hit rev limiter 5400rpm 85 mph on gps
34 natural bravo= prop wanted blow out while planing. 5000rpm 91mph on gps
31 hydrmotive p5x = prop never blew out,plained out at 2100 rpms,boat turns better and seems like it runs smoother.5200 rpms 92mph on gps. I dont think the 34 bravo would plain out with full fuel and 5 people, it was on the verge of blowing out until about 45 mph. The p5x ran a little faster and it never wanted to blow out ever. Made the boat feel totally different. Seems like a great prop, thanks Julie at throttle up. I told her my numbers and she got me the right prop the first try!
We also tested another 25 daytona with a double step and a really high x dimension. He could not plain out with the 34. He was using a 32 lab bravo and clicked 112 on the gps. It also wanted to blow out a little. With the p5x he plained out easily and he went 115 mph on gps and he never blew the prop out.
My rpms were 5200. His were 6300 on his recall tach. He thinks he could have went maybe a little faster but the rear of his boat was getting a little squirelly he said. I am not running a nose cone and he is. I wonder what that would do for my numbers. He of course is running a much bigger motor.
How did they carry the nose? I thought the P5X is a bow lifting prop. I run the regular P5s and the Spectre runs flat, but when I run the Bravo 4 blades, the nose is about a foot higher than when the Hydromotives are on the boat. I like the Hydromotives much better.
good info on setups...
i have a 25 single step and have monkeyed around with many props...according to eliminator (jerry may), the single step should be setup to run "flat" and the two-step with 5 degrees of bow lift...
i tried a 5 blade 30p hering....blew out trying to plane..had major issues trying to get hering to "fix" it....it looks real nice hanging in the garage...
various 4 blade b1....and settled on a 32p non-labbed...right at 112 at 5600
my setup issue was to get rid of the 60-80 mph "hop"...i was told to have the "rake" taken out of the 4 blade to give a little more transom lift to make the boat run flat...
very interested in the details on the setup with the 5 blade hydro...where is the "x", how much trim, any mid range "hop"....
thanks
gm
thanks
gm
thanks
gm
thanks
gm
10% slip is about right for a cat....
on the calculator...
5600 (hit limiters) @ 10% with 1.36 gears and a 32 pitch prop gets you at 115mph....so 112 was right in there...
i have found a big difference in props at "cruising" speeds.. i use 3000 rpm as my reference....i see 60mph with the 32p 4 blade...with the 5 blade hering it was slower (55 mph)...that did not make much sense to me...
are either of the 25's discussed above using a standoff box???
gm
gm
