What type of oil for a HP500 (carb) >
Old 11-01-2004 | 07:33 PM
THATS IT's Avatar
Default What type of oil for a HP500 (carb)
Just wondering what weight oil every one is using in there HP500 ( carb ).
The flame arrester says SAE40 but the book says 20/50.
Is there a big difference? ( in laymans terms ).
Joe
THATS IT is offline
Old 11-01-2004 | 08:11 PM
Dave1972's Avatar
Default Re: What type of oil for a HP500 (carb)
No offense THATS IT, but this subject will give you so many responses your head will spin. It's been talked about and debated forever. I was going to respond that straight 40 weight dino oil is good stuff, but would say that full-synthetic is better in just about any way. I have been using Mobil 1 15W-50 for a long time with good results. Many have used Redline and Amsoil as well as Mobil 1 20W-40. In my opinion Hydrocruiser will give you the best answer and is an expert in the field. Either way, one of the more important factors is oil-change interval. Regardless of what you use, as long as you change it frequently you will save problems and reduce wear. Good luck
Dave1972 is offline
Old 11-01-2004 | 10:41 PM
ActiveThunderTodd's Avatar
15-50 mobil one - I have never put anything in mine other then that. 500 hours and no failurs of any kind...plan on getting a lot more out em too.
ActiveThunderTodd is offline
Old 11-02-2004 | 07:34 PM
THATS IT's Avatar
Joe
THATS IT is offline
Old 11-02-2004 | 08:08 PM
Hydrocruiser's Avatar
Arrow Re: What type of oil for a HP500 (carb)
Joe
I have been giving the viscosity issue a lot of thought and have done much additional research. Here is where I stand right now on the topic:
Boaters using any "non-hopped" up application should be fine going with a premium conventional 30WT. If you want to go to a synthetic then Mobil-1 15W-50 is great; if you want what I think is the best overall choice then go with Redline 15W-40. It protects like a straight weight and being a premium synthetic outperforms Mobil-1 15W-50. Redline has much better load bearing qualities due to it's additive system. The hands down winner here. No slam intended towards Redcap Mobil-1; if price is an issue then use Mobil-1.
If you have a "hopped engine" then a conventional premium 20W-50 like Kendall or Castrol GT is worth a look. Mobil-1 15W-50 would be a jump up from any conventional oil. Depending on how hopped up it is I would cast a vote if you are running very hard and high HP engines you consider either 20W-50 Redline; 20W-50 Mobil-1 V-twin or 20W-60 Redline. The Redline
20W-60 having the best all around base and additive system.
Hydrocruiser is offline
SeaWeasel
6
05-27-2008 06:01 PM
Stormrider
12-17-2004 12:38 AM
jdnca1
4
11-14-2004 06:34 PM
Semper Fi
0
11-12-2004 10:58 AM
shawn
3
07-09-2003 07:42 AM
