Hd / Tivo
Old 11-06-2004 | 09:21 PM
Tinkerer's Avatar
Default Hd / Tivo
What do you guys think of the new High Def TIVO box by HUGES???
What can I get one for $$$ other than the store for $999
Tinkerer is offline
Old 11-07-2004 | 12:13 AM
Audiofn's Avatar
Charter Member #232
Default Re: Hd / Tivo
999 is the price. They finally seem to be getting them in stock at stores. Make SURE you go through the entire set up proceedure or you will have problems with it. They work extreamly well. They still do not have decreet IR or RS-232 for control but other then that I have no complaints. I have installed about 15 of them and had 2 bad ones.
Jon
Put your best foot forward!
Audiofn is offline
Old 11-07-2004 | 01:45 AM
robyw1's Avatar
I just use Time Warner HD-DVR. I have been able to load a lot of HD shows on it and have plenty of space left.
Roby
robyw1 is offline
Old 11-07-2004 | 08:33 AM
Since I use cable, Im waiting on the HD model. In a dream world I hope it comes with 2 tuners, and good connections (DVI) etc.
CM
yahoo is offline
Old 11-07-2004 | 09:10 AM
gdfatha's Avatar
My EX got the Sleekcraft
I have a Sony two tuner Directv and TIVO box. I have decided not to do the HD yet due to the limited number of HD channels.
gdfatha is offline
Old 11-07-2004 | 09:20 AM
Audiofn's Avatar
Charter Member #232
CM
They have activated the DVI output on the dvr and non dvr Motorola boxes.
Jon
Audiofn is offline
Old 11-07-2004 | 09:23 AM
Audiofn's Avatar
Charter Member #232
Most people that I have installed them for use them for the games (NFL). There will be a substantial amount more programming this year as the "deadline" draws closer.
Jon
Audiofn is offline
Old 11-08-2004 | 10:22 PM
Tinkerer's Avatar
Tinkerer is offline
Old 11-09-2004 | 05:23 AM
When do you think they will make one that can record HD, or at least pass the signal thru.
My wife and I are addicted to our tivo. I tried the DVR from Time warner, could not stand the search feature, it was almost useless.
Curtis
yahoo is offline
Old 11-09-2004 | 06:50 AM
Audiofn's Avatar
Charter Member #232
Yahoo: Do you mean for Cable? Or Satellite? The Hughes unit is for Satellite. It gives you the ability to record two different streams at once and watch a recorded show, watch one and record another and so on. It does record in TRUE HDTV format or in standard def.
As for Cable I would not hold your breath. As from what I understand there are copy protection issues that will be a while for them to figure out. We are having enough problems with the DVI and HDMI standard in this industry as it is and that is with out using things to record (the very thing that these two standards were created to prevent)
Jon
Jon
Audiofn is offline
